I have a on-off switch that'll use for a kill switch for my car using the gas pump. The switch says 6A/125V 3A/250V 22 AWG. For my purpose it needs to handle 12V 20 Amps max.
    \$\begingroup\$ Note that the answers in the other question say: DC specs are typically much lower than AC for the same switch. Than was repeated a couple of times there and it won't hurt to repeat it here. \$\endgroup\$
    – user80875
    Jun 4, 2020 at 14:43
    \$\begingroup\$ Will a 6A switch work for 20A? No. \$\endgroup\$
    – user16324
    Jun 4, 2020 at 14:46
You cannot use a 6A switch with a 20A load. You may also run into issues with lower voltage rating at DC, but that hardly matters as you are already so far beyond the current rating.
