Schematic per each logic or gate of TI 74LS32
Hi, I have included the image of the schematic of the Texas Instrument 74LS32. Basically the chip consists of 4 OR gates and the schematic shows the logic how 1 of those gates is set up on the chip. In the figure shown on the LS32 version (the RHS schematic) is a transistor made up of a squiggly S on the body of it where the straight line would normally be, compared to the normal illustration of a transistor illustrated in the 32 schematic(LHS schematic). The same thing again with the diodes the ones on the right have squiggles and the ones on the left don't. I think I remember that this is a reverse breakdown diode? (but would like confirmation) I have a theory that this is illustrating a PNP transistor? But am not sure. Also I was wondering what is that italicized upside down pitchfork thingy right before GND sink? Insights would be appreciated.
    \$\begingroup\$ The word you're looking for is "Schottky". The "LS" in 74LS32 stands for Low power Schottky. (and the pitchfork is a GND symbol) electronics.stackexchange.com/questions/55073/… \$\endgroup\$
    – user16324
    Jun 4, 2020 at 19:30
  • \$\begingroup\$ thank you appreciate \$\endgroup\$
    – Klever5548
    Jun 4, 2020 at 19:40
That is an NPN transistor with integrated Baker Clamp. It can be known as a Shottky Transistor Wikipedia.
It is equivalent to this:
The diode between the collector and base prevents the transistor from saturating - if the collector attempts to go less than ~0.5V it will divert charge away from the base.
By preventing saturation the transistor can turn off more quickly because there will be less stored charge in the base region.
The diodes shown with the similar embellishment to the symbol are Shottky diodes. They are not to be confused with a zener diode that usually only have the bracket on one side, a backward diode that have them pointing the same way outwards or a tunnel diode where they both turn inwards.
Shottky diodes are diodes where one of the electrodes is a metal, rather than both being semiconductor. The turn-on voltage is significantly less and they have essentially zero stored charge so they are very fast.
The three pronged symbol is a connection to ground or in the case of an IC it is to the substrate. It also often means the connection to chassis in equipment or old schematics.
  • \$\begingroup\$ Wow thank you this is very insightful :) Do you know about the upside-down pitchfork thingy too? \$\endgroup\$
    – Klever5548
    Jun 4, 2020 at 19:38
  • \$\begingroup\$ @Klever5548: the pitchfork thingy is one of several commonly-used Ground symbols. \$\endgroup\$ Jun 4, 2020 at 19:45
  • \$\begingroup\$ Some people use "baker clamp" to refer specifically to the kind that uses two standard pn diodes; it might be worth mentioning that the schottky transistor symbol does specifically mean the type with a single schottky diode. \$\endgroup\$
    – Hearth
    Jun 4, 2020 at 20:08
  • \$\begingroup\$ ok thank you Peter and Hearth \$\endgroup\$
    – Klever5548
    Jun 4, 2020 at 20:10
