I have two circuits where one side is earth reference and another floating. The floating circuit is isolated by a transformer and talk to the earth reference circuit via opto-coupler.
During final phase of development, i noticed my floating ground shield got too close of the chassis ground with only less than 0.1mm of gap. I immediately tagged it as issue and as usual people will ask me how much gap I needed. (I don't really have an answer, I am only a mfg engineer). I go through some safety standard but I still don't have an clear answer.
Here is my question:
Do I need to have clearance between two grounds to avoid hazard or arc?
Since both points are concealed within a metal cover which are grounded, do I need to follow the clearance requirement as required by the safety standard?
- if that is not required, then how much of gap do I need to prevent a arc over? Should I follow the safety standard clearance guideline or should i follow the 30kV/cm rules?
