I'm trying to identify this potentiometer as accurately as possible:
Photo of potentiometer
On the rear it says: B5K.
It has two rows of 3 pins each:
(1,2,3)
(1,2,3)
Below are some measurements taken with my multimeter between pins 2 and 3, and the unit is: kΩ.
When taking the measurements, I was making small increments. I tried to make the same increment amount each time. But you know, I'm human and the increments were not totally perfect. I did this 4 times, see the following graphs:
Measurement graph 1
Measurement graph 2
Measurement graph 3
Measurement graph 4
Can you identify this potentiometer?
What's the nature of this potentiometer? linear, logarithmic, etc?
Where I could buy it?
Is there any other data I would need to provide, in order to properly identify it?
Thanks!
  • \$\begingroup\$ Are the measurements done in the original board, or after de-soldering the part? \$\endgroup\$
    – TooTea
    Commented Jun 5, 2020 at 19:18
If it's a "B" type, it should be linear. From your plots, it's not very linear, but it's definitely not logarithmic either.
So it's a 5K linear potentiometer. Given the tolerances, a 4.7K one would probably also work if you can't find 5K.
As per the comment by Hearth, if it's got 6 pins, it will be a dual-gang 5K pot.
    \$\begingroup\$ Sounds like it's a double-ganged pot, too; might want to mention that. \$\endgroup\$
    – Hearth
    Commented Jun 5, 2020 at 11:41
