Integrator
I have been using op-amp TL072C in charge integrator configuration. R = 1k Ohms and C = 100 uF. Vin is a DC signal of 1 V. VCC = 10 V and VSS = -10 V.
I get the expected output which is VSS, when a DC signal given as input. But the strange thing is that virtual ground voltage increases to about 0.65 V after output reaches VSS. Attached the screen shot. Snapshot
Why does the virtual ground voltage increases after output reaches to -VSS or saturation voltage ?
  • Probe 3: Input
  • Probe 1: Output
  • probe 2: Virtual Ground
  • \$\begingroup\$ Are you sure it was a TL072 op-amp? Is the question why it reaches 0.65 volts instead of 1 volt or is it about why it stops being a virtual ground? \$\endgroup\$
    Jun 6, 2020 at 7:24
  • \$\begingroup\$ It is TL072. The question is why it stops being virtual ground after output is saturated. \$\endgroup\$ Jun 6, 2020 at 7:40
    \$\begingroup\$ It saves others time if you add a link to the datasheet what you are using. Think of it next time when you ask a chip related question. In some cases there are multiple vendors for the same main part number. Though in general they are identical, there might be nuances between their behaviour. \$\endgroup\$ Jun 7, 2020 at 11:59
7 Answers 7
8
An op-amp with negative feedback tries to maintain the inverting input at the same voltage as the non-inverting input by adjusting the output voltage so that the potentials are equalized. Once the op-amp output hits the end-stops, it no longer can continue to adjust the output in the correct direction to maintain a virtual earth.
  • \$\begingroup\$ Got it. Does it mean that if output didn't hit the rail (VSS ), virtual ground would be maintained at near 0V since non-inverting end is tied to ground ? Other question: Do you think that it should have reached 1 V instead of 0.65 V, why ? \$\endgroup\$ Jun 6, 2020 at 8:07
    \$\begingroup\$ Correct and it's easier to analyse in a pure op-amp amplifier circuit - just think of the op-amp as an error amplifier in a control loop - it tries to minimize the error just like any control system does (if that makes sense to you). It should reach the same voltage as the input because once the output hits a solid end stop, you can think of the capacitor as an open circuit but, maybe as Spehro said in his answer, the capacitor is a bit leaky or is an electrolytic with the wrong polarity across it. \$\endgroup\$
    Jun 6, 2020 at 8:09
  • \$\begingroup\$ Cool. I do have electrolytic capacitor there. I will flip it and check. \$\endgroup\$ Jun 6, 2020 at 8:20
  • \$\begingroup\$ @NaveenSajjanar You shouldn't really be using electrolytic capacitors in integrators because of this very problem. Flipping it may fix today's problem but it just means that when you input a different voltage the problem occurs again. \$\endgroup\$
    Jun 6, 2020 at 8:26
  • \$\begingroup\$ ok. I will keep that in mind. \$\endgroup\$ Jun 6, 2020 at 8:40
If you have an ideal op-amp with infinite power supplies, the integrator output voltage would integrate to minus infinity as the capacitor needs to be charged with 1mA to keep the op-amp inverting terminal at 0V.
However you have a real world op-amp with limited supply voltage. As soon as the output voltage hits the output limit, it cannot go any more negative and it will stop pulling current via the capacitor so it cannot keep the inverting input at 0V.
One would expect the voltage to increase to the input voltage, since there is no longer dv/dt to draw current from the resistor.
Since it is not, that implies either measurement error or a large leakage current through the capacitor (maybe an electrolytic capacitor with the wrong polarity).
op-amp
Here are your op-amp internals.
If you shut off (1) by raising it to Vcc+, then you pinch off (2) which pinches off the mirroring (3)s. You've effectively shut down half of your differential pair. With the right (3) pinched off, all of the current flowing down from the top current source feeding the differential pair (input jfets), the current now has nowhere to go in it's normal path when operating correctly.
Instead of that current going through (3)s, it has to go entirely through the gate of (4) to get to Vcc-.
Further, it has to either go through the resistor or go through (5)'s gate and then another resistor.
This means that you'll at least have a Vbe + resistance or Vbe + Vbe + resistance depending on the two resistor values at the bottom terminal of IN+'s jfet. Jfets are transistors which require ~0.7 volts to turn on. So you'll generally have the input floating at 0.7 above the prior semi-calculated number.
  • \$\begingroup\$ Thanks for the explanation. I partially understood your answer. Can you please draw the current direction when in normal operation and when node 1 is shut off ? It will make it more clear for me. Is this phenomenon only limited to JFET amplifiers ? \$\endgroup\$ Jun 6, 2020 at 8:03
  • \$\begingroup\$ @horta You would get more upvotes if you turned your wall of text into separate lines or paragraphs, making it much easier to read. Just a heads-up. \$\endgroup\$
    – user105652
    Jun 6, 2020 at 22:49
  • \$\begingroup\$ The current of the tail current source can flow through C1 and Q5 to VCC-. A typo: bipolar transistors have bases, not gates. Thumbs up for adding the schematic from the datasheet! \$\endgroup\$ Jun 7, 2020 at 11:56
If the output Voltage reached the vss. The capacitor C is nearly cut off. So the feedback branch / C doesn't work. The invert input voltage can be What you input. It is no longer VIRTUAL Grounded. Caution, too high voltage may destroy the op amplifier. For more details, See the Data sheet of the op Amplifier.
  • \$\begingroup\$ Can you explain what "the capacitor C is nearly cut off" means? \$\endgroup\$ Jun 7, 2020 at 9:54
  • \$\begingroup\$ As time went by, The capacitor C was gradually charged fully, So there's no current flow through the Capacitor. Actually, The feedback loop of op amplifier was open then. So the virtual grounding doesn't stand anymore. \$\endgroup\$ Jun 8, 2020 at 3:55
This ubiquitous circuit can be explained in many ways... and all they will be true. But what is important here, is to show the meaning of all this in a clear way... to ask the question, "What does the op-amp really do here?"
Well, it keeps a steady virtual ground... but how does it do this magic? Virtual ground is an abstract concept for beginners. Then can we explain the circuit operation without it? It would be useful for you to see how I have done it in another answer to the same question:
https://electronics.stackexchange.com/a/502087/61398
The virtual ground is generated by the gain of the feedback loop. If the output of the amplifier saturates, it can't provide any gain and thus the virtual ground collapses.
If no gain is present, then leakage currents will define the voltages. The leakage current might even come from parasitic devices which are not shown in the schematic.
My explanation of rising to 0.65V and then to 1V: The fact that it reaches 0.65 very fast, indicates that a diode starts to clamp it. The JFETs use pn junctions to modulate the cross section of a resistive channel and therefore pn junctions are present between the gate and the source/drain. The current flowing into the non-inverting terminal is due to such reverse bias current of the pn junction. This current flows downwards and increases the voltage at the drain of the input JFET very fast in the beginning, because the bottom current mirror is deactivated. As soon as this voltage approaches the threshold voltage of the mirror's beta helper transistor (0.6-0.7V), the helper starts to conduct current and the base voltage of the mirror starts to raise. As a consequence the mirror will conduct current and swallows the leakage current of the input JFETs gate-drain junction. It is a negative feedback and it will stabilize itself, what the oscilloscope has shown us as well.
