I am reading this application note from Texas instrument : http://www.ti.com/lit/an/slyt187/slyt187.pdf?ts=1591543592096&ref_url=https://www.google.fr/. The application note give us the transfer function Vout/Iout of an LDO built with a PMOS. Here is the model :
Here is the transfer function :
where R12 is equal to :
I have actually some troubles to understand why Rds is in parallel with the capacitor Cb. The voltage across Rds is equal to (Vin - Vout) and the voltage across Cb is equal to Vout ? So why Rds is in parallel with Cb ?
Thank you very much and have a nice day :D (I know that I have some troubles with AC model)
    \$\begingroup\$ That's not the transfer function, that's the output impedance. \$\endgroup\$ Jun 7, 2020 at 18:56
  • \$\begingroup\$ Vout/Iout cannot be a transfer function ? \$\endgroup\$
    – Jess
    Jun 7, 2020 at 19:03
    \$\begingroup\$ sure, that's the transfer of the output impedance without load. Not the transfer function of the complete system. \$\endgroup\$ Jun 7, 2020 at 19:32
    \$\begingroup\$ It's a good article but has (minor) errors in schematic. Vi is assumed AC short (ideal) yet R1,R2 >> Rds so R1, R2 can be neglected. Zo "shud be" left of load. \$\endgroup\$ Jun 7, 2020 at 19:48
  • \$\begingroup\$ Thank you for your comments. Do you know where I can find a better model than this one ? I found also this one but it is clearly a complex model, nevertheless it might be the right one ! onsemi.com/pub/Collateral/AND8037-D.PDF \$\endgroup\$
    – Jess
    Jun 8, 2020 at 15:01
When we're working out the equivalent resistance of some network, we treat ideal voltage sources as shorts. In this analysis we're assuming the input (\$V_i\$) is being provided by an ideal voltage source. Therefore the source terminal of the PMOS is connected to ground, for the purpose of this analysis.
Since \$C_b\$ is also connected between the output terminal and ground, that puts \$C_b\$ and the drain-source branch of the MOSFET in parallel.
