I have an electrical power generator and for it to properly work with it connected to the house it must be converted from bonded neutral to floating neutral according to these instructions. I was thinking of attaching a switch to be able to easily change from bonded and floating without having to remove the cover and wire each time I want to use the generator connected to the house or when using standalone.
I haven't found a simple toggle switch that can hold the max amp and voltage. I was then thinking of an isolation switch used on cars for batteries. I've seen some that can withstand 500 amps, but at 12 DC Volts. Would that work? I want something small I can attach inside the housing. Any recommendations and what specifications I should look for?
My Generator produces a max of 50 amps at 240 AC Volts.
The bonding cable is the top right white cable. Generator Housing
Battery isolation switch Battery cut off switch
  • \$\begingroup\$ I do hope when using the generator to power the house, you are using a proper isolator to avoid running in parallel with the mains supply. \$\endgroup\$
    – Simon B
    Jun 8, 2020 at 17:23
  • \$\begingroup\$ Disclaimer: I'm not an electrician. Don't listen to me. USA. Have you searched for a 'Safety Switch'. They come in all sizes. 60Amp : $80. Despot Depot: Home->Electrical->Power Distribution->Safety Switches \$\endgroup\$ Jun 8, 2020 at 18:29
  • \$\begingroup\$ Disclaimer: I'm not an electrician. Don't listen to me. USA. ...Also mechanical "Disconnect Switches" come in both fusible and non-fusible varieties. Same $80/60A price point from the common online distributors. "Switch, Disconnect,600 VAC,4,65 mm,16 lb. in.,Extended/Direct Handle Motor" \$\endgroup\$ Jun 8, 2020 at 18:33
  • \$\begingroup\$ @SimonB thought I could use both for extra power. I kid, of course, I have a 100 Amp Manual Transfer Switch. \$\endgroup\$
    – Rick
    Jun 8, 2020 at 18:34
  • \$\begingroup\$ Single-pole or double-pole? Location information might help. Add it to your question or to your user profile. \$\endgroup\$
    – Transistor
    Jun 8, 2020 at 19:45
