I used the "c2d" to discretize a transfer function initially but MATLAB automatically took it as zero order hold because I didn't specify any kind of hold. The result for the zero order hold is different from the expected result. I’m not trying to use any hold in my discretization. Is there a way I can do this?
Read the documentation https://www.mathworks.com/help/control/ref/c2d.html and figure what discretization method you want, since you clearly don't want zoh
sysd = c2d(sysc,Ts,method)
The following methods are available, and each will have its pros and cons:
  • zoh
  • least-squares
  • matched
  • tustin
  • impulse
  • foh
