Is my thinking of half wave voltage Tripler Circuit right?because my thinking is a little bit different from the book's
Book Let the input is a sine wave with amplitude \$=V_m\$ enter image description here
1.When input is the first positive half wave,\$D_1\$ on,and \$C_1\$ will be charge to \$V_m\$
2.When input is the first negative half wave,\$D_1\$ off,and \$D_2\$ on ,and \$C_2\$ will be charge to \$2V_m\$
3.When input is the second positive half wave,\$D_1\$ on, \$D_2\$ off,and \$D_3\$ on ,and \$C_3\$ will be charge to \$2V_m\$
now the \$V_O=V_{C1}+V_{C3}=3V_m\$
My opinion enter image description here
1.When input is the first positive half wave,\$D_1\$ and \$D_3\$ on,and \$C_1\$ and \$C_3\$ will be charge to \$V_m\$
enter image description here 2.When input is the first negative half wave,and we add the sine input with the voltage of \$C_1\$,the amplitude of input will become \$2V_m\$,now \$D_1\$ and \$D_3\$ off,\$D_2\$ on ,and \$C_2\$ will be charge to \$2V_m\$
3.When input is the second "positive" half wave,and we add the sine input with the voltage of \$C_2\$,the amplitude of input will become \$3V_m\$, and \$D_1\$ and \$D_3\$ on,and \$C_3\$will be charge to \$3V_m\$.and the voltage of \$C_3\$ is the \$V_o\$
I want to ask is my thinking about the half wave voltage Tripler Circuit right?if wrong,which part of my thinking is wrong,can anyone tell me?thx a lot!
  • \$\begingroup\$ that works with negative 3x pk relative to the top line AC if you define that as 0Vdc. (or neutral). Same but inverted to convention. \$\endgroup\$
    – D.A.S.
    Commented Jun 9, 2020 at 7:20
  • \$\begingroup\$ @TonyStewartSunnyskyguyEE75 So you think my thinking is right? \$\endgroup\$
    – XM551
    Commented Jun 9, 2020 at 10:56
  • \$\begingroup\$ You are correct for 101 theory. For 201 add a ground symbol and maybe for 301 theory, try estimating the current spike if you had a switch close at worse case sin (90 deg) using 1 Amp rated 1N400x diodes. What is your skill level? Could you draw the supply current waveforms during startup? Are you the same person @XM551 or twice as smart. \$\endgroup\$
    – D.A.S.
    Commented Jun 9, 2020 at 13:36
  • \$\begingroup\$ Do you understand the limitations of your assumptions? and how to ask a better question? \$\endgroup\$
    – D.A.S.
    Commented Jun 9, 2020 at 13:40
  • \$\begingroup\$ @TonyStewartSunnyskyguyEE75 NO,what is the 101 theory you mention? \$\endgroup\$
    – tester_ga
    Commented Jun 9, 2020 at 15:20
