I'm having problems simulating the following circuit using ngspice alongside Qucs.
The main problem I can see in log is that is acusing an singular matrix.
I imagine the problem is related to how the transformer is placed, but could not find anything related.
The ngspice code generated is:
* Qucs 0.0.19  /home/eduardo/projetoSimoes/qucs/initialCircuit.sch
.SUBCKT Bridges_GBU4G  gnd  _net0 _net1 _net2 _net3
DD1 _net1 _net0 DMOD_D1
.MODEL DMOD_D1 D(Is=2.46092e-06 N=2.62593 Rs=0.00370811 Cj0=2.8562e-10 Vj=0.25 M=0.332534 Fc=0.5 Tt=2.88539e-06 Bv=440 Ibv=0.05 Af=1 Kf=0)
DD2 _net1 _net2 DMOD_D2
.MODEL DMOD_D2 D(Is=2.46092e-06 N=2.62593 Rs=0.00370811 Cj0=2.8562e-10 Vj=0.25 M=0.332534 Fc=0.5 Tt=2.88539e-06 Bv=440 Ibv=0.05 Af=1 Kf=0)
DD3 _net2 _net3 DMOD_D3
.MODEL DMOD_D3 D(Is=2.46092e-06 N=2.62593 Rs=0.00370811 Cj0=2.8562e-10 Vj=0.25 M=0.332534 Fc=0.5 Tt=2.88539e-06 Bv=440 Ibv=0.05 Af=1 Kf=0)
DD4 _net0 _net3 DMOD_D4
.MODEL DMOD_D4 D(Is=2.46092e-06 N=2.62593 Rs=0.00370811 Cj0=2.8562e-10 Vj=0.25 M=0.332534 Fc=0.5 Tt=2.88539e-06 Bv=440 Ibv=0.05 Af=1 Kf=0)
.ENDS
XD1 0  _net0 _net1 _net2 Vout Bridges_GBU4G
V1 Vin 0 DC 0 SIN(0 127 60 0 0) AC 127
R1 _net1 Vout  36
C1 _net1 Vout  1U
L2 0  Vin 1
L1 _net2  _net0 1
K1 L1 L2 0.1
.control
echo "" > spice4qucs.cir.noise
echo "" > spice4qucs.cir.pz
tran 0.0001 0.1 0
write initialCircuit_tran.txt v(Vin) v(Vout)
destroy all
reset
exit
.endc
.END
The logs are:
Ngspice started...
Warning: singular matrix:  check nodes l2#branch and l2#branch
Note: Starting dynamic gmin stepping
Trying gmin =   1.0000E-03 Note: One successful gmin step
Trying gmin =   1.0000E-04 Note: One successful gmin step
Trying gmin =   1.0000E-05 Note: One successful gmin step
Trying gmin =   1.0000E-06 Note: One successful gmin step
Trying gmin =   1.0000E-07 Note: One successful gmin step
Trying gmin =   1.0000E-08 Note: One successful gmin step
Trying gmin =   1.0000E-09 Note: One successful gmin step
Trying gmin =   1.0000E-10 Note: One successful gmin step
Trying gmin =   1.0000E-11 Note: One successful gmin step
Trying gmin =   1.0000E-12 Note: One successful gmin step
Warning: Dynamic gmin stepping failed
Note: Starting source stepping
Supplies reduced to   0.0000% Warning: singular matrix:  check nodes l2#branch and l2#branch
Trying gmin =   1.0000E-02 Note: One successful gmin step
Note: One successful source step
Supplies reduced to   0.1000% Warning: singular matrix:  check nodes l2#branch and l2#branch
Warning: source stepping failed
Circuit: * qucs 0.0.19  /home/eduardo/projetosimoes/qucs/initialcircuit.sch
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Transient solution failed -
Last Node Voltages
Node                                   Last Voltage        Previous Iter
_net0                                   1.74481e-22          6.32215e-27
_net1                                   1.74481e-22          6.32215e-27
vout                                   -9.83511e-33         -1.26443e-26
vin                                               0                    0
l1#branch                               8.92061e-35                    0
l2#branch                                         0                    0
v1#branch                                         0                    0
doAnalyses: iteration limit reached
tran simulation(s) aborted
Error(parse.c--checkvalid): vin: no such vector.
ngspice-26 done
The schematic is:
Circuit
  • \$\begingroup\$ Try putting a 0.001 ohm resistor in series with the transformer primary (this sort of thing has happened before to me). Also, shift the ground connection from the primary to the DC secondary - if you need to monitor the primary voltage you can use a VCVS to buffer that 1:1 to the secondary side as a signal. Vout cannot be "measured" without earth at the DC secondary. \$\endgroup\$ – Andy aka Jun 9 '20 at 18:43
  • \$\begingroup\$ @Andyaka adding the resistor to the transformer pimary and GND to both sides worked. But the Vout measurement is still not the one expected. Any thoughts. I'm really newbie to circuit simulation. \$\endgroup\$ – Eduardo Amaral Jun 9 '20 at 18:59
It turns out I needed to add GND to the second part and add a little resistor to simulate the transformer primary resistance.
The soltion was:
Circuit
