**EDITED
I am supposed to build a boost converter that steps-up a 1.5V input to 5V (also I only have 1.5V as my power source). I have designed the circuit out but the only problem I face right now is that I can't turn the MOSFET on with 1.5V peak-max. I am using a B012N03LX3 MOSFET as my switch.
This is my schematic connection btw (assume that the Diode is ideal and assume that NE555 can operate with 1.5V which the simulation show that it can) Also I check the datasheet and I know that the Vgs(th) must be at least 1V to turn the MOSFET on
Also I check the datasheet and I know that the Vgs(th) must be at least 1V to turn the MOSFET on enter image description here
And the Vne555 has the output of this (10kHz with 0.7 Duty Cycle)
But the voltage output at Vload is
So from this I am pretty sure that the MOSFET did not get sufficient voltage at Vgs(th) to turn on. But due to the fact that I only have 1.5V as my voltage supply I am not sure what correction I need to do to my circuit to make sure that the MOSFET is able to turn on (with only 1.5V as a voltage source) properly
Btw I think the output should look like this if the MOSFET is able to turn on properly enter image description here
So any idea on what should i change in my circuitry to make it work?
  • \$\begingroup\$ @MarcusMüller oh actually I don't have a 15V source. I am just using it to test the switch out. But I did try to switch the power source to 1.5V (which is the only power source that I am suppose to have) for the NE555 with near to 200mA and -200mA coming out from the output but with the duty cycle of less than 0.1 percent which I am not so sure why. \$\endgroup\$
    – tw.C4444
    Jun 14 '20 at 18:29
  • \$\begingroup\$ Welcome to EE.SE! Why are you using a 555 instead of a purpose made chip for the application? \$\endgroup\$
    – winny
    Jun 14 '20 at 18:48
    \$\begingroup\$ @Andyaka ya its the waveform when I connect to the MOSFET gate, I think all I have to the to fix it is to fix the waveform for the current (not sure if I am right,correct me if I wrong) but I have no idea how to solve it tbh \$\endgroup\$
    – tw.C4444
    Jun 14 '20 at 19:54
    \$\begingroup\$ No, 1V is where the MOSFET barely begins to turn on. Look at its datasheet : the Rds((on) is specified at Vgs = 4.5V (and at 10V) and that is what you should aim to drive it with. And a 555 won't work at 1.5V (check its datasheet) - though your simulation model might. \$\endgroup\$ Jun 15 '20 at 13:52
    \$\begingroup\$ You could rig up 2 transistors as an astable multivibrator. But replacing the 555 won't solve the gate drive voltage problem. \$\endgroup\$ Jun 15 '20 at 15:10
Vgs(th) it's just to start driving, to really serve as a switch you need VGS = 4.5 V (see rds(on))
You must try other circuits as follow
boost converter 1.5 volts input 5 volts output 200 mA, boost converter 1.5 volts input 5 volts output 10 mA, boost converter 1.5 volts input 5 volts output 500 mA, boost converter 1.5 volts input 5 volts output 300 mA
Question: "MOSFET did not get sufficient voltage at Vgs(th) to turn on..what correction"
Answer: Since there is an oscillator, make a charge pump (voltage double or triple). Then switch that voltage on the FET gate.
One thing you may try, just to see it on the simulator is:
Shift the operating point, by adding two resistors and a capacitor
1.5V--Ra--(X)--Rb--GND, (X)--FET gate, (X)--Cx--555 output.
If you ever manage to get it started, add oring diodes from 1.5vdc/output to vcc. Keep in mind this will make your start-up challenges more difficult but your gate drive will be much stronger once its operational.
If you ever manage to get it started, add oring diodes from 1.5vdc/output to vcc. Keep in mind this will make your start-up challenges more difficult but your gate drive will be much stronger once its operational. Remember to use shottky diodes.
Edit: you could use a transiator (add a series resistor with the base). You only need .7v to drive a 2222a.
No, you are misreading the data sheet. What it says is that, in order to get 250 uA drain current, some FETs will only require 1 volt, but some will need 2.2 volts.
You are using 1.5 volts as a supply voltage, so you would have to get quite lucky in picking your FET to get one which will work in your circuit. It's even worse than you think since you want much more than 250 uA, which means you need an even higher gate voltage.
