I am trying to trigger ADC1 to convert (for the moment) one channel of a STM32F429ZI microcontroller (on the Nucleo Board) by TIM2 every second. With the code below I configured 180 MHz core frequency, a timer underflow every second (working), the ADC to convert channel 3 with 480 ADC clock cycles (@22.5 MHz) sample time and 12 bit resolution. So with the abovementioned configuration I would have expected ~22 µs conversion time of the ADC.
To check for the conversion time I need to use Segger SystemView as I don't have an oscilloscope. Contrary to my expectation the ADC interrupt service routine (ISR 34) is called 2.6 µs after the timer interrupt (ISR 44)
Can someone explain why the ADC is converting so fast?
Code:
* SEGGER Microcontroller GmbH *
* The Embedded Experts *
* (c) 2014 - 2020 SEGGER Microcontroller GmbH *
* www.segger.com Support: support@segger.com *
* All rights reserved. *
* Redistribution and use in source and binary forms, with or *
* without modification, are permitted provided that the following *
* conditions are met: *
* - Redistributions of source code must retain the above copyright *
* notice, this list of conditions and the following disclaimer. *
* - Neither the name of SEGGER Microcontroller GmbH *
* nor the names of its contributors may be used to endorse or *
* promote products derived from this software without specific *
* prior written permission. *
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND *
* CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, *
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE *
* DISCLAIMED. *
* IN NO EVENT SHALL SEGGER Microcontroller GmbH BE LIABLE FOR *
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR *
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT *
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF *
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT *
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE *
* USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH *
* DAMAGE. *
-------------------------- END-OF-HEADER -----------------------------
File : main.c
Purpose : Generic application start
#include <stm32f4xx.h>
#include "SEGGER_SYSVIEW.h"
void ClockInit(void)
uint32_t timeout = 1000000;
// enable flash prefetch
FLASH->ACR |= FLASH_ACR_PRFTEN;
// set 5 wait states (needed for high PLL frequency)
FLASH->ACR &= ~FLASH_ACR_LATENCY_Msk;
FLASH->ACR |= FLASH_ACR_LATENCY_5WS;
do
timeout--;
} while (((FLASH->ACR & FLASH_ACR_LATENCY_Msk) != FLASH_ACR_LATENCY_5WS) && (timeout > 0));
// switch on external clock, bypass HSE with it and wait for clock to be ready
RCC->CR |= (RCC_CR_HSEON | RCC_CR_HSEBYP);
timeout = 1000000;
do
timeout--;
} while (((RCC->CR & RCC_CR_HSERDY_Msk) != RCC_CR_HSERDY) && (timeout > 0));
// configure (HSE as clock source, M = 4, N = 180, P = 2), enable and wait for PLL
RCC->PLLCFGR = (RCC_PLLCFGR_PLLSRC_HSE | (4 << RCC_PLLCFGR_PLLM_Pos) | (180 << RCC_PLLCFGR_PLLN_Pos));
RCC->CR |= RCC_CR_PLLON;
timeout = 1000000;
do
timeout--;
} while (((RCC->CR & RCC_CR_PLLRDY_Msk) != RCC_CR_PLLRDY) && (timeout > 0));
// configure rest of clock tree
RCC->CFGR &= ~(RCC_CFGR_PPRE2_Msk | RCC_CFGR_PPRE1_Msk | RCC_CFGR_HPRE_Msk);
RCC->CFGR |= (RCC_CFGR_PPRE2_DIV2 | RCC_CFGR_PPRE1_DIV4 | RCC_CFGR_HPRE_DIV1);
// set PLL as clock source and wait until clock is ready
RCC->CFGR &= ~(RCC_CFGR_SW_Msk);
RCC->CFGR |= RCC_CFGR_SW_PLL;
timeout = 1000000;
do
timeout--;
} while (((RCC->CFGR & RCC_CFGR_SWS_Msk) != RCC_CFGR_SWS_PLL) && (timeout > 0));
SystemCoreClockUpdate();
// enable GPIOA, ADC1 and TIM2 clocks
RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN;
RCC->APB2ENR |= RCC_APB2ENR_ADC1EN;
RCC->APB1ENR |= RCC_APB1ENR_TIM2EN;
void TimerInit(void)
// counter direction down, generate update event only on underflow
TIM2->CR1 |= (TIM_CR1_DIR | TIM_CR1_URS);
// set update event as trigger source
TIM2->CR2 &= ~TIM_CR2_MMS_Msk;
TIM2->CR2 |= TIM_CR2_MMS_1;
// enable update interrupt
TIM2->DIER |= TIM_DIER_UIE;
// set timer and reload value for update generation every 1000 ms
TIM2->ARR = TIM2->CNT = 90000000;
void TimerStart(void)
TIM2->CR1 |= TIM_CR1_CEN;
void AdcInit(void)
// PA3 as analog input
GPIOA->MODER |= GPIO_MODER_MODE3;
// set clock prescaler to 4 -> 22,5 MHz
ADC123_COMMON->CCR |= ADC_CCR_ADCPRE_0;
// enable timer 2 trigger event as start trigger on rising edge and generate EOC interrupt after each conversion
ADC1->CR2 |= (ADC_CR2_EXTSEL_2 | ADC_CR2_EXTSEL_1 | ADC_CR2_EXTEN_0 | ADC_CR2_EOCS);
// set 480 cycles sample time for channel 3
ADC1->SMPR2 |= ADC_SMPR2_SMP3;
// set channel 3 as first (any only) regular channel
ADC1->SQR3 |= (ADC_SQR3_SQ1_2 | ADC_SQR3_SQ1_1);
// enable EOC interrupt
ADC1->CR1 |= ADC_CR1_EOCIE;
// enable ADC
ADC1->CR2 |= ADC_CR2_ADON;
void InterruptInit(void)
// Timer 2
NVIC_SetPriority(TIM2_IRQn, 3);
NVIC_ClearPendingIRQ(TIM2_IRQn);
NVIC_EnableIRQ(TIM2_IRQn);
// ADC
NVIC_SetPriority(ADC_IRQn, 2);
NVIC_ClearPendingIRQ(ADC_IRQn);
NVIC_EnableIRQ(ADC_IRQn);
void TIM2_IRQHandler(void)
SEGGER_SYSVIEW_RecordEnterISR();
TIM2->SR &= ~TIM_SR_UIF;
void ADC_IRQHandler(void)
uint16_t Value;
Value = ADC1->DR;
int main(void)
ClockInit();
SEGGER_SYSVIEW_Conf();
TimerInit();
AdcInit();
InterruptInit();
TimerStart();
while(1);
/*************************** End of file ****************************/
