I need to buy a 9 pole mini din plug (male) to create a ps2 -> quadrature mouse adapter but I'm a little concerned the socket I'm connecting to is non-standard:
Rear of an Archimedes 440/1 keyboard [Angled view displaying notch better2
The reason I think this is the top 3 pins are not evenly distributed and the data sheets I look at for ordering online have them evenly distributed.
So my questions are:
  1. Is this socket standard?
  2. Are the datasheets wrong?
  3. Could I buy a 10 pin, and just pull one of the pins out of the plug?
  • \$\begingroup\$ The middle row is also not evenly distributed, although it's close enough that you could probably force it. \$\endgroup\$
    – Dave Tweed
    Jun 15, 2020 at 13:47
  • \$\begingroup\$ So are you saying the socket in the photo is non-standard @DaveTweed? \$\endgroup\$
    – John Hunt
    Jun 15, 2020 at 14:11
    \$\begingroup\$ No, I'm just making an observation based on your photo. What exactly is the piece of equipment? \$\endgroup\$
    – Dave Tweed
    Jun 15, 2020 at 14:27
  • \$\begingroup\$ search for mini din connector leads to ebay.com/itm/… ... it is for Promedia GMX \$\endgroup\$
    – jsotola
    Jun 15, 2020 at 21:43
  • \$\begingroup\$ @DaveTweed this is the back of an Archimedes computer keyboard - and you're looking at the mouse socket. In this case it's a 440/1 system built around 1987 I think. The Archimedes line of computers used a non-standard mouse system called 'quadrature' - really weird. I'm using my Arduino to translate a ps/2 optical mouse into the right protocol for this. I've ordered a 9 pin minidin with flylead from RS components, it wasn't cheap but I didn't fancy soldering the mini-din. The Archimedes was one of the first 32 bit personal computers and was the first to use an ARM chip. Very cool, v.fast. \$\endgroup\$
    – John Hunt
    Jun 16, 2020 at 9:02
Pinwise, yes, it seems to me that all 9-pin mini din connectors are that way, with an uneven first row, which is also found in the 10-pin model. If there are no differences in dimension, there shouldn't be any problems using a 9-pin din on it. Although that happens to be my experience, the fact that the datasheets indicate otherwise would make me second-guess myself.
Although, it does not seem to feature the two little notches near the bottom, common in the mini din connector, which might make it incompatible.(EDIT: A new picture shows that it does indeed have the notches.)
Well, it seems to me that they could, but it is hard to say, really. You should look for a datasheet with measurements to see if it really is non-standard.
I don't think the two bottom row pins would necessary align if you remove the middle one of a 10-pin. But perhaps with some force you could, although it would not be ideal.
  • \$\begingroup\$ Note - I think the notch doesn't show in the photo clearly.. the top is cut out to a depth of a few mm within the circle. \$\endgroup\$
    – John Hunt
    Jun 15, 2020 at 14:14
  • \$\begingroup\$ I meant these two notches near the bottom. \$\endgroup\$
    – Funest
    Jun 15, 2020 at 14:17
  • \$\begingroup\$ Thanks - it has those, I've added another photo that shows them much more clearly (in hindsight that first photo was really misleading!) \$\endgroup\$
    – John Hunt
    Jun 15, 2020 at 14:18
  • \$\begingroup\$ Looking at it now, I see no reason to believe that a standard 9-pin wouldn't work. If need be, the 10-pin might even work in a pinch. \$\endgroup\$
    – Funest
    Jun 15, 2020 at 14:20
  • \$\begingroup\$ Perfect, thanks for your help! \$\endgroup\$
    – John Hunt
    Jun 15, 2020 at 14:24
