I'm designing a "1011" overlapping sequence detector,using Mealy Model in Verilog.
The FSM that I'm trying to implement is as shown below :-
Verilog Module :-
`timescale 1ns / 1ps
module seq_detector(
input x,clk,reset,
output reg z
parameter S0 = 0 , S1 = 1 , S2 = 2 , S3 = 3 ;
reg [1:0] PS,NS ;
    always@(posedge clk or posedge reset)
        begin
            if(reset)
                PS <= S0;
            else
                PS <= NS ;
        end
    always@(PS or x)
        begin
            case(PS)
                S0 : begin
                            z = 0 ;
                            NS = x ? S1 : S0 ;
                            $display(PS);
                        end
                S1 : begin
                            z = 0 ;
                            NS = x ? S1 : S2 ;
                            $display(PS);
                        end
                S2 : begin
                            z = 0 ;
                            NS = x ? S3 : S0 ;
                            $display(PS);
                        end
                S3 : begin
                            z = x ? 1 : 0 ;
                            NS = x ? S1 : S2 ;
                            $display(PS);
                        end
            endcase
        end
endmodule
Testbench :-
module testbench;
    // Inputs
    reg x;
    reg clk;
    reg reset;
    // Outputs
    wire z;
    // Instantiate the Unit Under Test (UUT)
    seq_detector uut (
        .x(x),
        .clk(clk),
        .reset(reset),
        .z(z)
initial
    begin
        clk = 1'b0;
        reset = 1'b1;
        #15 reset = 1'b0;
    end
always #5 clk = ~ clk;
initial begin
        #12 x = 0;#10 x = 0 ; #10 x = 1 ; #10 x = 0 ;
        #12 x = 1;#10 x = 1 ; #10 x = 0 ; #10 x = 1 ;
        #12 x = 1;#10 x = 0 ; #10 x = 0 ; #10 x = 1 ;
        #12 x = 0;#10 x = 1 ; #10 x = 1 ; #10 x = 0 ;
        #10 $finish;
    end
endmodule
Simulation Output :-
The issue is that, I'm getting the number of '1011' detected to be correct (i.e. 3 according to the testbench). But the timing where the output is going high is wrong. The output 'z' is going high when '101' is being detected, when it's expected to go high when '1011' occurs. What's the possible modification that I'd have to do, so as to eliminate this error ?
The error is caused by mixing the combinational State assignment block with the sequential output block. The combinational state assignment block and the sequential output block have different sensitivity lists.
Following these guidelines helped me design glitch-gree FSMs.
  1. Sequential blocks use nonblocking assignments.
  2. Combinational blocks use blocking assignments.
  3. It's better to use registered outputs.
  4. Use combinational logic for the state assignment block
Link to the design on EDA Playground
Design:
 input x,clk,reset,
 output reg z
 reg [1:0] PS,NS ;
 //sequential state register block
 always @ (posedge clk or posedge reset)
   if (reset)
     PS <= S0;
   else
     PS <= NS;
 //sequential output block
   if (reset)
     z <= 1'b0;
   else
     z <= (PS == S3) && x;
 //combinational state assignment block
 always @ (*)
  begin
    case(PS)
        S0 : NS = x ? S1 : S0 ;
        S1 : NS = x ? S1 : S2 ;
        S2 : NS = x ? S3 : S0 ;
        S3 : NS = x ? S1 : S2 ;
    endcase
  $monitor(PS);
  end
 endmodule
Testbench:
 module testbench;
 // Inputs
 reg x;
 reg clk;
 reg reset;
 // Outputs
 wire z;
 seq_detector uut (
    .x(x),
    .clk(clk),
    .reset(reset),
    .z(z)
initial begin
$dumpfile("dump.vcd");
$dumpvars(1, testbench);
fork
    clk = 1'b0;
    reset = 1'b1;
    #15 reset = 1'b0;
begin
    #10 $finish;
end
join
end
endmodule
Waveform: https://www.edaplayground.com/w/x/3Pj waveform
    \$\begingroup\$ Could you please elaborate here ? such as pasting the code ? links only answers are not suited because they might become dead at some point.... \$\endgroup\$
    – Blup1980
    Commented Jun 16, 2020 at 6:03
  • \$\begingroup\$ @Blup1980, yes I have done it. Thank you for your suggestion \$\endgroup\$ Commented Jun 16, 2020 at 6:34
  • \$\begingroup\$ Hi Shashank, can you please explain why your output goes high in the same cycle as the last bit in 1011 goes high? Shouldn't output go high only in the next cycle because you have used output as a flop by means of the <= and the posedge block? \$\endgroup\$
    – penguin99
    Commented Dec 9, 2021 at 17:13
  • \$\begingroup\$ @penguin99 z <= (PS == S3) && x; Because x is a direct input to the output, so it gets updated in the same cycle \$\endgroup\$ Commented Aug 6, 2022 at 15:33
Great answers by Shashank, but I would like to highlight a subtle issue with registered outputs, i.e. a delay of one clock cycle between the change of state and the change of outputs. This is easy to overcome by slightly rearranging the logic. This rearranged topology keeps the outputs synchronised to both the clock and the change of state. It works by calculating the next outputs from the next state (which is subtly different from calculating the present outputs from the present state). Then the next state and the next outputs are clocked through together at the next positive clock edge.
Schematic of fully synchronous Mealy machine
Figure 1 – Schematic of fully synchronous Mealy machine.
Fully Synchronous Mealy Machine of Sequence Detector in SystemVerilog
module SequenceDetector
    parameter NUM_STATES = 4,
    parameter NUM_TRANSITIONS = 8,
    parameter NUM_INPUTS = 1,
    parameter NUM_OUTPUTS = 1
    input logic clock,
    input logic reset,
    output logic [$clog2(NUM_STATES) - 1 : 0] state,  // Optional feedback to outside world.
    input logic seq,
    output logic det
    typedef enum int unsigned
        S0,
        S1,
        S2,
        S3
    } TState;
    localparam TState STATE_RESET = S0;
    localparam [0 : NUM_OUTPUTS - 1] OUTPUTS_RESET = 1'b0;
    TState present_state;
    TState next_state;
    logic [0 : NUM_INPUTS - 1] inputs;
    logic [0 : NUM_OUTPUTS - 1] outputs;
    logic [0 : NUM_OUTPUTS - 1] next_outputs;
    // State register and outputs register
    always_ff @(posedge clock or posedge reset)
    begin
        if (reset)
        begin
            state <= STATE_RESET;
            present_state <= STATE_RESET;
            outputs <= OUTPUTS_RESET;
        end
        else
        begin
            state <= next_state;          // Synchronised to clock.
            present_state <= next_state;  // Synchronised to clock.
            outputs <= next_outputs;      // Synchronised to clock and change of state.
        end
    end
    // Next state logic
    always_comb
    begin
        case (present_state)
            S0: case (inputs)
                    1'b1: next_state = S1;
                    1'b0: next_state = S0;
                    default: next_state = S0;
                endcase
            S1: case (inputs)
                    1'b0: next_state = S2;
                    default: next_state = S1;
                endcase
            S2: case (inputs)
                    1'b1: next_state = S3;
                    default: next_state = S2;
                endcase
            S3: case (inputs)
                    default: next_state = S3;
                endcase
            default
            begin
                $error("Reached invalid state.");
                next_state = STATE_RESET;
            end
        endcase;
    end
    // Next outputs logic
    always_comb
    begin
        if (present_state == S3 && next_state == S1)
            next_outputs = 1'b1;
        else
            next_outputs = 1'b0;
    end
    // Input signals
    assign inputs =
        seq
    // Output signals
    assign
        det
    } = outputs;
endmodule
Test Bench
`timescale 1ns/10ps
module SequenceDetector_TB();
    localparam NUM_STATES = 4;
    localparam NUM_INPUTS = 1;
    localparam NUM_OUTPUTS = 1;
    logic sys_clock;
    logic reset;
    logic [0 : $clog2(NUM_STATES) - 1] state;
    // Inputs
    logic seq;
    // Outputs
    logic det;
    initial
    begin
        sys_clock = 1'b1;
        reset = 1'b0;
        seq = 1'b0;
    end
    // Clock generator
    always
    begin
       #5 sys_clock = ~sys_clock;
    end
    // Stimulus
    always
    begin
        #22 reset = 1'b1;
        #20 reset = 1'b0;
        { seq } = 0;
        #10 { seq } = { 1'b1 };
        #10 { seq } = { 1'b0 };
        #45;
        $stop;  // Stop the simulator.
    end
    // Device under test
    SequenceDetector SequenceDetector_Inst
        .clock(sys_clock),
        .reset(reset),
        .state(state),
        .seq(seq),
        .det(det)
endmodule
Simulation
Simulation of sequence detector
Figure 2 – Simulation of sequence detector.
More Mealy Information
Compare the fully synchronous Mealy machine of Figure 1 with the following Mealy machines.
Schematic of Mealy machine
Figure 3 – Schematic of Mealy machine.
Schematic of Mealy machine with registered outputs
Figure 4 – Schematic of Mealy machine with registered outputs.
The registered outputs create a kind of pipeline architecture so the outputs are 1 clock cycle behind the state.
The rearranged topology of Figure 1 keeps the outputs synchronised to the state by lumping the combinational logic together which calculates the next_outputs from the next_state. To reiterate this subtle but important point: this is different from calculating the present outputs from the present state. A potential caveat of lumping the combinational logic together is that it removes the 'pipeline' so you might need a lower clock frequency to allow the combinational logic to settle.
As an example, full synchronisation is important for an IoT Factory 4.0 environment where a snapshot (state and outputs) of all the machines in a factory needs to be taken periodically.
You can redraw it like this fully synchronous generic state machine. Whether its Moore or Mealy fades into esoteric academicism. Just write the combinational logic for your requirements.
Schematic of fully synchronous generic state machine
Figure 5 – Schematic of fully synchronous generic state machine.
    \$\begingroup\$ @ShashankVM, if you rearrange the logic, it is fully synchronised to both the clock and change of state. \$\endgroup\$
    – tim
    Commented Jan 21, 2021 at 15:03
    \$\begingroup\$ Figure 1. \$\endgroup\$
    – tim
    Commented Jan 21, 2021 at 15:06
    \$\begingroup\$ Moore state machine. Moore state machine with registered outputs. Fully synchronous Moore state machine \$\endgroup\$
    – tim
    Commented Jan 21, 2021 at 15:12
    \$\begingroup\$ It has an advantage and a disadvantage. Registered outputs creates a kind of pipeline architecture so the outputs are 1 clock cycle behind the state. Rearranging keeps the outputs synchronised to the state by lumping the combinational logic together which calculates the next_outputs from the next_state. A potential caveat of lumping the combinational logic together is that it removes the 'pipeline' so you might need a lower clock frequency to allow the combo logic to settle. \$\endgroup\$
    – tim
    Commented Jan 21, 2021 at 15:27
    \$\begingroup\$ As an example, full synchronisation is important for an IoT Factory 4.0 environment where a snapshot (state and outputs) of all the machines in a factory needs to be taken periodically. \$\endgroup\$
    – tim
