I have designed a PCB board for one of my projects. The PCB is about 60*80mm
in size. I have done various tests in the lab,and now I will have to install it in the required location. However, I have been struggling to finalize the type of battery to use. I want the whole setup to be compact and not have any moving and detachable parts. The operation of the PCB and my calculations for the battery so far are:
There are two modes of operation for the PCB. They are:
- Deep-sleep mode –Current consumption is about
1.5mA
- Operation mode –Current consumption is about
120mA
The PCB operates once in every hour, and stays in operation mode for ~30seconds (or ~0.0084 hours)
. And the rest of the time it is in deep-sleep mode.
So the average current consumption is:
C=(0.0084*120+0.9916*1.5) mAhr
C≅2.5 mAhr
PCB Operating voltage is between 3.3V
and 4.2V
. And in the future depending on the battery I can change the Power regulation circuit.
The current consumption is measured at 4.2V
. (Can I use only this for energy calculation?).
Hence the Energy required is:
E=4.2*2.5 mWhr
E=10.5mWhr
I need to choose a battery to power the PCB for about 3000 Hours. So the energy requirement is:
E=10.5*3000 mWhr
E=31500mWhr≅32Whr
If I use a Z V
battery of R mAhr
rating and assume the power regulator in the PCB is P%
efficient, then the energy provided by battery is:
Eb=Z*R*P
Generally, for the better long-lasting performance, batteries cannot be discharged for more than 80%
of its energy( So I have learned).
Hence the revised Energy of battery is:
Eb=0.8*Z*R*P
We need a battery of E
energy. Assume P=80%
Eb=E=0.64*Z*R
32Whr=0.64*Z*R
Z*R=50 Whr
If Z=12V, then R~ 4.2Ahr
If Z=24V, then R~2.1Ahr
If Z= 5V, then R~10Ahr
If Z= 3.7V(Typical Batteries) , then R~13.5Ahr
I can see many batteries online which , I think, can server my requirement. However, due to None-Little experience in this field, I am unable to consider the practical aspects. And also most of the batteries for this requirement seems to be little bigger. I am aware of the fact that I need to consider shelf-life
of a battery and C
rating as well, but don't know how to do it.
Can anyone please suggest me which type of batteries will suit my project well?
I hope all my calculations are correct. If there are any mistakes please consider correcting them.
Thanks in advance!
