See the document here.
I am interested on using external interrupts, and trying to configure NVIC at register level. The statement below, which can be found in page 215, confused me:
Each priority field holds a priority value, 0-255. The lower the value, the greater the priority of the corresponding interrupt. The processor implements only bits[7:4] of each field, bits[3:0] read as zero and ignore writes.
Especially the bold part.
If that explanation was not present, I would directly think that I can write any number (0-255) to those 8 bit fields to set the priority. But now, I am confused such that whether I can use bits [3:0] or not.
  • \$\begingroup\$ the written values in range of 0 to 255 are 'mapped' to 16 priority vales by ignoring 4 lower bits. \$\endgroup\$
    – Juraj
    Jun 16, 2020 at 12:23
  • \$\begingroup\$ @Juraj how about writing 128 and 129 ? They both translate(mapped) to 8? \$\endgroup\$
    – muyustan
    Jun 18, 2020 at 10:15
  • \$\begingroup\$ not to 8. to 128. \$\endgroup\$
    – Juraj
    Jun 18, 2020 at 12:01
  • \$\begingroup\$ @Juraj ok, considering left most 4 bits, they both will be 8. Then they have the same priority although I intended to make them different (128 and 129) \$\endgroup\$
    – muyustan
    Jun 18, 2020 at 12:46
  • \$\begingroup\$ you can't. the datasheet says they are the same priority. \$\endgroup\$
    – Juraj
    Jun 18, 2020 at 12:48
Since the MCU implements 4 bits out of 8, you have 16 priorities and they are stored in high 4 bits of the 8 bit value. So you may not use the 4 lowest bits (unless you always keep them zero that is).
  • \$\begingroup\$ I've been thinking about this for a while, so far, I understood that I can only have 16 different levels of priority between all interrupts. I accepted this. But, is there a specific reason why it is not implemented in the lower 4 bits instead of higher 4 bits which would make a lot more sense(in my opinion, at least) ? \$\endgroup\$
    – muyustan
    Jun 19, 2020 at 17:33
