I am reading this datasheet and I want to drill the correct size hole into the board and I am confused what 5-ΓΈ1.2 means.
I can't understand what the 5 and - sign mean? Your help would be greatly appreciated.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIt means that there are 5 (quantity) of these holes, each has a diameter of 1.2 mm (+0.1 mm / -0 mm).
There are 5 holes (marked in blue) that need to be drilled 1.2 mm diameter.
It doesn't mean 5 minus 1.2 OR 5 minus \$\phi\$
It means there are five of that hole somewhere on the diagram. Each one is nominally 1.2mm in diameter and can be up to 0.1mm larger than nominal or 0mm smaller than nominal.
