Greetings beloved comrades,
I recently acquired a 36v golf cart that has 6 6v batteries in series. The existing 12v accessories, mainly lights, are powered by a separate series connection to 2 of the 6v batteries.
I don't like tapping only 2 of the batteries, since prolonged usage will imbalance the batteries and possibly require individual charging.
My question is: Can I wire 3 12v circuits in parallel from the 6 batteries for an always active supply, or would it be better to add a separate switched 36v circuit and a buck converter to get 12v?
I would prefer the first solution just to avoid buying a chunky switch and converter, but if the latter is better is for efficiency/battery life, I'll go that direction.
Unlikely. The power draw from the accessories is probably small as compared to the engine draw.
Can I wire 3 12v circuits in parallel from the 6 batteries for an always active supply.
Not if you still need 36V for the engine as well.
I assume you want to use the 36V from the engine supply. You can convert this down to 12V but that seems overkill and will also create some non-trivial losses (and cost)
If you are really worried about asymmetric use, simply switch the accessories to a different battery pair every 100 hours or so. If the accessories share a common ground with the engine, than you can just shuffle the batteries instead.
  • \$\begingroup\$ Ok, that's what I figured. No common ground, so I'll start swapping on a schedule. Thank you. \$\endgroup\$ Jun 17, 2020 at 15:57
