18
Today I stumbled across a piece of information that surprised me. Apparently there is a minimum cable length for SATA. From Seagate, a reputable manufacturer of SATA devices:
Serial ATA (SATA) data cable lengths
Serial ATA cables are available in many lengths up to 1 meter. Minimum cable length is 12 inches, using shorter cables can cause timing, or noise interference on the cable.
That is all the information they offer, and I could not find much information elsewhere. It is obvious that a cable can be too long: Signals will arrive too late, and eventually become attenuated. This is the first time I hear about cables being too short.
Since they measure the minimum length in inches it makes me think that it is not in the official standard, and something that they have found by trial-and-error, but can someone explain why this would be a problem in a (presumably well designed) standardized high frequency serial protocol?
    \$\begingroup\$ I dunno but all the SATA cables I have ever bought and used are shorter than 12" \$\endgroup\$
    – DKNguyen
    Commented Jun 18, 2020 at 18:55
    \$\begingroup\$ Interesting - perhaps due to setup/hold violations from a reflection that comes back too quickly? Clutching at straws a bit..! \$\endgroup\$
    – awjlogan
    Commented Jun 18, 2020 at 19:09
  • 8
    \$\begingroup\$ Laptops and tiny PCs like Intel NUC have much shorter SATA cables, or even no cable at all as the SSD plugs into the PCB directly.... Also SATA M.2 SSDs don't use a cable at all. So this is quite weird. \$\endgroup\$
    – bobflux
    Commented Jun 18, 2020 at 19:26
    \$\begingroup\$ Strange one. I've just built a PC and put 0.2m SATA cables in, they're freely available. \$\endgroup\$
    – TonyM
    Commented Jun 18, 2020 at 19:28
    \$\begingroup\$ I'm reserving judgement. However, with "Seagate, a reputable manufacturer of SATA devices", it seems that you're supplying evidence of the opposite. ;-) \$\endgroup\$ Commented Jun 18, 2020 at 19:32
27
I have designed SATA asic serdes circuits and do not recall issues with short cables.
However, we do test for very long and very short length test cases to ensure sufficient signal integrity at either extreme, as sometimes a timing circuit or equalizer misbehaves when the signal is too clean.
For instance the timing recovery relies on a sloped transition between 0 and 1, and if the cable is too short, then the 0-to-1 and 1-to-0 slopes are too steep, and the timing recovery can become noisy (it's a long story). This can be an issue in asic test set-ups, but hardly in real deployments.
However, 12in seems to be a ridiculously high minimum.
    \$\begingroup\$ Could it be about mismatch at the connectors causing reflections that if the cable is too short could make a glitch appear within the hold time of the serdes? \$\endgroup\$
    – Dan Mills
    Commented Jun 19, 2020 at 10:53
    \$\begingroup\$ @DanMills, it's hard to say. I think an earlier commenter is right, that perhaps the short cables had poor mismatch, the long ones had better match (for reasons not related to the length), and so the FA (field application engineer) wrote a quick comment based on that observation, understandably, without further investigation. At 6Gbps I can't see that somehow a mismatch at 13in is worse than a mismatch at 4in. But again, from a distance, it's hard to say. \$\endgroup\$
    – P2000
    Commented Jun 19, 2020 at 16:46
    \$\begingroup\$ I could see the reflected power from the mismatch making an edge non monotonic which might be a bigger issue for the CDR at the shorter length, the front end likely has way more then 3GHz bandwidth. I normally play with SDI rather then SATA but the rates are broadly similar. High speed signalling has some really funky ways to go sideways (And of course FAEs writing notes without actually investigating is no great surprise, one does not always discover genius). \$\endgroup\$
    – Dan Mills
    Commented Jun 19, 2020 at 17:20
  • \$\begingroup\$ Out of curiosity, in your experience what length do the issues come from? I'm not familiar with what "asic test set-ups" are and I think just a small note about how long that implies would be super helpful. :) \$\endgroup\$ Commented Jun 19, 2020 at 20:36
  • \$\begingroup\$ @CaptainMan the set-up could be a loop-back out-to-in of the same ASIC that has two serdes connections -perhaps 1 inch loopback trace-, or between two ASICs generally on the same board, so they are perhaps a few inches apart. This is used to evaluate or test a pre-production spin of an asic, to perform S/W development at-speed, etc.. The serdes design itself might be subject to tests, or it could just be used as an IO to test other parts . \$\endgroup\$
    – P2000
    Commented Jun 20, 2020 at 0:25
14
I searched the SATA 3.0 spec and could not find anything that would indicate there is a minimum cable length for SATA cables. I assume there isn't one.
There is a lot on the cables being too long, depending on the application and speed 1m to 2m seems to be the max length.
I would say design SATA cables as short as you want to. Seagate has made USB storage drives that have the SATA controller less than an inch or two from the controller. I don't see why they have included a minimum length on their website, it does not violate SATA specs (as far as I can tell).
I also can't think of a physical reason besides reflection that would dictate a minimum cable length, but the connectors are tightly matched so this shouldn't be much of a problem either.
    \$\begingroup\$ If Seagate controls both sides of the cable, they may exceed official specifications. \$\endgroup\$
    – MSalters
    Commented Jun 19, 2020 at 11:18
    \$\begingroup\$ Segate normally doesn't control both sides of the cable in almost all cases as they don't make motherboards \$\endgroup\$
    – Voltage Spike
    Commented Jun 19, 2020 at 23:10
  • \$\begingroup\$ @VoltageSpike I think you missed the "USB storage devices" part. \$\endgroup\$
    – Coxy
    Commented Jun 21, 2020 at 12:47
