I have 2 microcontrollers - one is S32K118 and other is S32K142. Both are 64 pins. S32K1xx datasheet
I need communication between the Microcontrollers in SPI Configuration.
Suppose the microcontroller supports 2 LPSPI modules, say LPSPI0, LPSPI1, LPSPI2.
For that, I need to connect the LPSPI0 module pins from one microcontroller to the LPSPI0 module pins in the other microcontroller, right?
Or it doesn't matter if the SPI communication between one microcontroller and the another microcontroller takes places on different SPI modules, like say LPSPI0 in 1st and LPSPI1 in another microcontroller? or LPSPI1 in 1st controller and LPSPI2 in the second controller?
And what about the chip select pin?
Which module should I select for the chip select in SPI communication between the microcontrollers? Why are they 2 modules for chip select? Like, which should I choose based on which will act as the master microcontroller initiating the SPI communication and which microcontroller will act as the slave.
This SPI Communcation is only between the 2 microcontrollers. Please explain to clear this confusion. Stuck here.
Any recommendations?
