The question that I'm trying to understand is the following:
In any series RC circuit that is in steady state, WHEN any of the elements changes (R, C, or applied voltage), the following will happen to the circuit:
(A) The circuit will briefly operate in steady state then gradually go on a transient state.
(B) The circuit will immediately go on a transient state then reach a steady state.
(C) The circuit will immediately go to a transient state.
My answer is B since, according to the textbook, the transient response is a circuit's temporary response that will die out with time and the steady-state response stays for a long time after an external excitation is applied. Now, is that external excitation include changes in any of the circuit elements?
    \$\begingroup\$ WHEN any of the elements (R, C, or applied voltage) what? when they do what? \$\endgroup\$
    Jun 19, 2020 at 13:01
  • \$\begingroup\$ @Andyaka, when they 'change.' Sorry, I edited the question already. \$\endgroup\$
    – romeoPH
    Jun 19, 2020 at 13:14
My answer is B
It all depends how they change - if they change to a new static value(s) then "B" is the answer. If they change and continue to change then "C" might be the answer.
Then there's the consideration of AC transient response.
If the input voltage becomes a sinewave i.e. is continuously changing sinusoidally, then the AC response on the output has a transient response leading to a non-static steady-state response because, the output will also "become" a sinewave (with phase shift) after the transient response has died down.
So, it all depends what you mean.
