can someone explain to me why does the current pass through his hands? why doesn't it pass only through the aluminum since electricity always chooses the easiest path? https://www.youtube.com/watch?v=7QIcdQPwLmg&t=331s
\$\begingroup\$ the video tells you how it is done youtu.be/7QIcdQPwLmg?t=287 \$\endgroup\$– jsotolaJun 19, 2020 at 18:09
\$\begingroup\$ well since skin has a way higher resistance than aluminum wouldn't current flow so low in his hands to the point he wouldn't feel it? \$\endgroup\$– zakaria kaisJun 19, 2020 at 18:09
\$\begingroup\$ listen to what he says at 4:57 \$\endgroup\$– jsotolaJun 19, 2020 at 23:48
1 Answer
We see later on in the video a clearer view of the handle of the jack in the box.
It has been wired with two separate pieces of aluminium foil, each connected to one side of the spark generator.
When you hold it with two fingers, one on each piece of foil, your fingers complete the circuit and allow a current to flow.
While not the reason for this, I want to correct a common misconception in your question:
This is not correct. A current will flow through all paths, with the flow being inversely proportional to the resistance of the path. If you connect a high value resistor in parallel with a low value resistor, current will flow through both - a larger current will flow through the low value resistor.
