Circuit
The 32VRMS secondary of a transformer feeds a full wave rectifier and capacitor filter as shown in the circuit.
The peak-to-peak ripple of the output voltage of this circuit needs to be less than 1V when it delivers a current of 3A. A filter capacitor of about 30 000 uF is required. I need to find the frequency.
I am unsure of the formula for finding peak-to-peak ripple voltage of a full wave bridge rectifier.
Is this correct:
V(p-p) = I/(2*f*C)
Therefore, f = 50 Hz.
I am unsure because I have seen the equation:
V(p-p) = Vm/(2*f* R*C)
used.
Which equation is correct?
    \$\begingroup\$ Have you tried to simulate it? Is this homework? \$\endgroup\$
    – winny
    Jun 22, 2020 at 7:59
  • \$\begingroup\$ It's not homework, i am just confused which formula to use \$\endgroup\$
    – John
    Jun 22, 2020 at 8:09
  • 4
    \$\begingroup\$ If you work at understanding the circuit from first principles you'll never have to remember the formulas or how to apply them. \$\endgroup\$ Jun 22, 2020 at 8:57
  • \$\begingroup\$ But i don't understand the circuit from first principles \$\endgroup\$
    – John
    Jun 22, 2020 at 9:05
    \$\begingroup\$ The first equation doesn't have any term denoting the load or the current drawn. A load which draws more current will definitely cause a bigger dip in the capacitor voltage. So first equation is probably wrong. In the second equation, there is an R in the denominator. A smaller R draws more current and hence more dip in the capacitor voltage. Hence the second equation is more likely correct. Derivations are usually given in most textbooks. \$\endgroup\$
    – AJN
    Jun 22, 2020 at 12:32
Vm/(2.f.R.C)=I/(2.f.C) as Vm/R =I where Vm is the max voltage
