-1
I'm tasked with making a few new pieces of eqipment based on an existing one. This piece uses a few clamps like below to hold wires (usually a few at a time) connecting individual components inside its case. The clamps are glued to the device's case on the inside. The wires they hold are pretty thin, up to about 3 mm in diameter (with insulation) so the clamps are too quite small, on the order of 15x7 mm (can't measure them now, I've already used up all that were in stock).
What's the official name for them that I can find and order them by? I searched by keywords like "metal wire clamp glue" but only larger ones, for entire cables, come up. Asking around at a large local electronics market also quite surprisingly yielded no results.
  • \$\begingroup\$ A generic trerm that may be useful in searching is "wire management" or "cable management". \$\endgroup\$ – Peter Bennett Jun 22 '20 at 16:26
It's a adhesive-mount metal cable clip. Similar to Panduit MACC25-AV-D (photo from here but they are available from regular electronics distributors).
  • \$\begingroup\$ The one in the post has a "movable" clip, this one appears to have a fixed clip \$\endgroup\$ – Voltage Spike Jun 22 '20 at 15:31
Sticky clamps or sticky pad clamps comes to mind.
So see https://www.pinterest.com/pin/826410600342624151/
All you need is a bit of effort in google “heat resistant sticky cable clamp”...
  • \$\begingroup\$ Likewise, only plastic ones for entire cables come up in search :\ \$\endgroup\$ – ivan_pozdeev Jun 22 '20 at 13:05
