I am trying to simulate an ultrasonic sensor using a ray-based approach. For that, my current process can roughly be described as such:
- approximate wavefront using rays that mimic the shape of the sensor's beam form
- subtract angle-dependent SPL loss for each ray
- calculate sound pressure level that gets reflected back to the sensor at each hit point, track Δt the ray needs to get back to the receiver
- subtract angle-dependent transmitter SPL loss
- aggregate SPL at the sensor given tuples of SPL and Δt from each ray (e.g. overlaying different echos arriving at the same time)
My calculated SPL always refers to the reference sound pressure of 20μP.
My problem is as simple as it is impossible for me to understand: I now have SPL values at the receiver ("measured" at 30cm distance from the sensor, as in most datasheets like here). However, I'm not sure how to determine whether the receiver can register an echo or not, which is where the sensitivity comes into play. As far as I understand from here and here, that value from the spec sheet describes how the receiver can translate sound pressure into a voltage.
This is not what I need, I just want to decide whether an echo is registered or not - can I just assume that the sensor can pick up any sound pressure impulse above the reference, i.e. 20μP or an SPL of 0dB? I feel like I am missing something very obvious here, but I cannot seem to be able to figure it out. Any help would be greatly appreciated!
