Is the 2nd step in the solution sheet wrong?
I don't know how they can just ignore the node where the 9 ohm resistor and the 12 ohm resistor were located. Wouldn't current be branched/divided when it flows from either the a or the b terminal through both the 18 and 9 ohm; and 12 and 6 ohm resistors, thus making the 2nd picture not a series circuit?
