I have been working on a simple circuit which performs XOR operation.
The problem is that I am seeing a noise-like graph when both inputs are set to 1 (5V) and I have been doing a research on what it could be but I have failed to find any explanation.
At first I was curious to see whether if the simulation program (Falstad simulator) added computer generated noise for some kind of "close to real life testing" purposes(?) but I figured that it would be unnecessary and there was no source to prove such point.
What could this graph possibly be indicating?
Note: Although the transistor on the schematic is displayed as BC547, it is not chosen to be this exact transistor in the simulator, instead the simulator uses default NPN transistor characteristics, not staying loyal to characteristics of this spesific transistor.
Here is the circuit diagram:
Here is the graph of Vout (which is V_LED):
