from the datasheet which one should I use? Thermal Junction to Case or Thermal Junction to Ambient?
Tj= Ta + Pd * Rth(j-c)
or
Tj= Ta + Pd * Rth(j-a)
when I use Rth(j-a), Tj become way too high, near TjMax.
If you use Rth(j-c) you either have to know the maximum case temperature or you have to add the thermal resistance of an external heat sink (case to heat sink + heat sink to ambient) and the maximum Ta.
So, you would use Rth(j-a). If you are getting too high a Tj using Rth(j-a) at the maximum Ta then you require a different package or a heat sink.
Don’t forget to account for switching losses and the large increase in Rds(on) at high temperatures and ensure you have sufficient gate drive voltage to get guaranteed Rds(on).
  • \$\begingroup\$ I already use Rds(on) at high temperature and Pd total (conduction losses, switching losses, dead time losses). Current at 30% mosfet can handle. \$\endgroup\$
    – urai5
    Jun 26, 2020 at 2:46
