This is a low pass filter:
This a high pass filter:
If we add a load resistor to the high pass filter it becomes like this:
The total resistance of the R1 with the RL will be lower than the smallest resistance(R1 or RL).
If we add a load resistor to the low pass filter it becomes like this:
The total impedance of the C1 with the RL will be lower than the smallest impedance(C1 or RL).
If we start from a frequency when the impendance of C1 is smaller than the impendance of RL then the strength of the signal passing through RL will depend on frequency.
However if the impendance of the load resistor becomes less than the impedance of the capacitor then the strength of the signal passing through RL will not depend anymore on frequency
(in both cases i am reffering to voltage not current passing through RL resistor)
Low pass filters stop working below below a certain frequency and high pass filter always work?
