I am trying to replace the SMD electrolytic capacitors from an LG E2442 but I am getting confused in regards to determining the correct values. I am trying to determine three different cspacitors types as shown in the images below.
I can somewhat determine some of the values of the first one but get really confused about the others.
enter image description here For the first Capacitor I believe:
100v = 100 Volts
27 = Capacitance but I am unsure what the symbol before and after it is therefore I don't know how that is modifying/multiplying the value
J = 5% Tolerance
33 = ???
Here is an image of the PCB with the capacitors in red circle in case it helps.
Any help would be greatly appreciated.
In all of those, the top number is a date code. Below that, the capacitance, followed by the voltage.
So 33uF/100V (that one looks bulged and is probably bad) 68uF/35V, 100uF/16V
The character following the capacitance is probably a series code, not a tolerance.
Be sure to match the polarity (black partial circle).
