I am struggling with an complementary amplifier and unable to compute the value and equations. My target is to identify the working of the circuit, its total gain and equations. After studying many circuits I learned that:
Gain of 1st stage A1 = 4700 / 200
Gain of 2nd stgge A2 = 1600 / 200  (I dont know if this is correct)
total gain A = A1 * A2  (I dont know if this is correct)
Q point for active region for 1st tage is
Icq1 = (V1 / (R6 + R1)) / 2
Q point for active region for 2st tage is
Icq2 = (V2 / (R2 + R3)) / 2  (I dont know if this is correct)
V6 = V4 + 0.7
I0 = I6 + I4
I6 = Icq1
I4 = Ib1 + Ie2 => Ib1 + Icq2
Ic1 = B * Ib1  With this equation I can calculate the required Ib for beta and Ic1 = Icq1
This is how far I go but I still don't know how this works. I want equations for the total gain and for the resister value selection because this is reference circuit and I don't have actual transistor Q7 and Q8 with reference beta values. Now if I use any other good transistor then the beta will change so we need to calculate new resister values to set the circuit in active region and total gain of > 32 dB. Also the bandwidth is > 3 Mhz. Input type is video signal.
    \$\begingroup\$ is there a component missing in the base of Q7? Why is that open cable there? \$\endgroup\$
    – MPA95
    Jul 6, 2020 at 23:30
  • \$\begingroup\$ Nothing is missing. It was mistake the open cables. \$\endgroup\$
    – user777304
    Jul 10, 2020 at 8:31
First I must say that it is easier to design such a circuit then to find the DC operating point. But let us try
You can use any network analysis technique you are familiar with.
I will use KVL.
First KVL loop looks like this: enter image description here
So the first equation will look like this:
$$(I_{C1} - I_{B2})R_{C1} =(I_{E2} + I_{B1})R_{E2} + I_{E2}R_{E3} + V_{BE2} \:\:\: (1) $$
The second KVL loop will look like this:
And the KVL equation around this loop: $$V_{CC} = (I_{E2} + I_{B1})R_{E2}+I_{B1}R_F+V_{BE1}+I_{E1}R_{E1} \:\:\: (2) $$
And from "transistor action" we know that:
\$I_E = I_B(\beta +1)\$ ; \$I_B =\frac{I_C}{\beta} \$ and \$I_B =\frac{I_E}{\beta+1} \$
Thus
$$(I_{C1} - \frac{I_{E2}}{\beta_2 +1})R_{C1} = V_{BE2}+ I_{E2}R_{E3} + (I_{E2} + \frac{I_{C1}}{\beta_1})R_{E2} \:\:\: (1) $$
$$V_{CC} = (I_{E2} +\frac{I_{C1}}{\beta_1} )R_{E2}+V_{BE1}+\frac{I_{C1}}{\beta_1 }\left(R_F+(\beta_1+1)R_{E1}\right) \:\:\: (2) $$
And for \$\beta_1 = 67 ;\: \beta_2=130\$ and \$V_{BE1} = V_{BE2} = 0.6V\$
I've got:
\$I_{C1} = 1.343mA\$
\$I_{E2} = 2.53mA\$
$$I_{C1} \approx \frac{(R_{C1} + \beta (R_{E2} + R_{E3}))V_{CC} - (R_{C1} + \beta R_{RE3}) V_{BE}}{\frac{R_{C1} (R_{E2} + \beta(R_{E1} + \beta R_{E2}) + R_F)}{\beta} + (R_{E2} + R_{E3})R_F + \beta R_{E1}(R_{E2} + R_{E3}) + R_{E2}R_{E3}}$$
And the voltage at \$Q_1 \$ collector is:
$$V_{C1} = V_{CC} - I_{C1}R_{C1} = 12V - 1.343mA \times 4.7k\Omega = 12V - 6.3V = 5.7V$$
and the voltage at \$Q_2\$ collector is:
$$V_{C2} = I_{C2}R_{C2} = I_{E2}\frac{\beta_2}{\beta_2+1} \times R_{C2} = 2.51mA \times 1.6k\Omega = 4V $$
For the AC (small-signal) analysis the equivalent circuit will look like this:
And the mid-frequency voltage gain is equal to:
$$\frac{V_{OUT}}{V_{IN}} \approx \frac{R_{C1}||(\beta +1)(R_{E3} + r_{e2})}{R_{E1} + r_{e1}} \times \frac{R_{C2}||R_L}{R_{E3} + r_{e2}}$$
If \$C_1\$ and \$C_2\$ have a higher capacity so that in the "mid-frequency" we can treat them as short circuit the gain will increase to:
$$\frac{V_{OUT}}{V_{IN}} \approx \frac{R_{C1}||(\beta +1)r_{e2}}{r_{e1}} \times \frac{R_{C2}||R_L}{r_{e2}}$$
Where
\$r_{e1} = \frac{V_T}{I_{E1}} \approx \frac{26mV}{I_{C1}}\$ \$r_{e2} = \frac{V_T}{I_{E2}} \approx \frac{26mV}{I_{C2}}\$
The End
  • \$\begingroup\$ I am still not clear about the total gain that I would get. The equations? \$\endgroup\$
    – user777304
    Jul 10, 2020 at 11:59
  • \$\begingroup\$ How you calculated VC1 and VC2? \$\endgroup\$
    – user777304
    Jul 10, 2020 at 12:01
  • \$\begingroup\$ @user777304 I edit my answer. What do you want to know or do not understand about the total gain? \$\endgroup\$
    – G36
    Jul 10, 2020 at 14:50
  • \$\begingroup\$ At output am opamp is connected in a comparators configuration. I want to know that what will be the out pulse amplitude if -1.4mV pulse is set at the input with PW 500ns. \$\endgroup\$
    – user777304
    Jul 15, 2020 at 0:09
