I have a circuit that looks like the following. It appears to be simple-
What's the thevenin equivalent? I can't seem to simplify it as there are no common nodes that any of the resistors connect.
    \$\begingroup\$ I would redraw this circuit first to clearly see what is parallel to what \$\endgroup\$
    – Eugene Sh.
    Jun 30 '20 at 17:35
    \$\begingroup\$ R5 to R1 is as R4 to R2 - redraw to make the image simpler - this always helps. \$\endgroup\$
    Jun 30 '20 at 17:44
  • \$\begingroup\$ If you redraw your schematic you will find that it is similar to a "Wheatstone bridge" (not invented by Wheatstone who only popularized another's invention) except that there is a resistor where a source usually is placed. It's a classic case suggesting that you memorize the \$\Delta-Y\$ conversions (both directions may be worth memorizing.) But it can also be solved out using nodal analysis, too. Are you familiar with nodal? \$\endgroup\$
    – jonk
    Jun 30 '20 at 19:32
  • \$\begingroup\$ As others say, you can re-draw this to make it more clear. Also, this problem is often given with further condtions, like R1=R2=R4=R5. If you were given that information, you can simplify the circuit even further with a clever trick. \$\endgroup\$
    – The Photon
    Jun 30 '20 at 20:52
Use the delta-wye transformation and then you’ll see parallel and series combinations of resistors you can reduce.
    \$\begingroup\$ Works like a charm- thanks! \$\endgroup\$ Jul 2 '20 at 17:13
