I a need 2 units of 2-to-1 selector/multiplexer functions on a crammed board, ideally with a single DIP-14 or -16 chip. Looking around for something I found this formula
(S nand A) nand ((not S) nand B)
which is great, as I can build it with a single 74LS00 quad NAND gate chip as:
(S nand A) nand ((S nand S) nand B)
So I know I can do it with two DIP-14 chips. But I want only one!
Truth table:
S A B|Y
L L x|L
L H x|H
H x L|L
H x H|H
or fully expanded sorted by binary value of S,A,B:
S A B|Y
L L L|L
L L H|L
L H L|H
L H H|H
H L L|L
H L H|H
H H L|L
H H H|H
or fully expanded sorted by Y
S A B|Y
L L L|L
L L H|L
H L L|L
H H L|L
L H L|H
L H H|H
H L H|H
H H H|H
I tried a combination of two NAND or two NOR gates also don't work. None gives a L L L -> L or H H H -> H.
A standard AND-OR-invert (AOI) gate also doesn't work as nothing gets any L L L L -> L or H H H H -> H. The 2-2 AOI gate will always output 0 if three or all four inputs are 1, and 1 if three or all four inputs are 0. Same problem with and OAI gate.
For a moment I thought the double XOR combination suggested in Can I simplify this to a 2-to-1 multiplexer? was going to do it, which would have been so nice as I could have built two with one chip, but then it doesn't work. It seems so close though!
Maybe I should say what I am really ultimately trying to do: I use 74LS161 counters (or any TTL counters) as registers, 4 bits (one nybble) each, and I have two such counters chained together where the ripple carry out of the low nybble connects to the clock of the high nybble. I want to be able to synchronously preset either one independently. Easy to do for the low nybble, not so easy for the high nybble as the synchronous load happens on the rising clock edge, and the clock for the high nybble is connected to the ripple carry output.
So I figured a selector should be doing it, but the 74' series only has quad 2-to-1 selector/multiplexer with a single selector, but I need two independent selectors!
Any trick? Perhaps a counter which can be synchronously pre-set but has a different ripple clock input from the clock edge that triggers the pre-loading? That's really all I want. Oh boy, if it could also be three-state it would be perfect. But none such exists. That's why I am so short on space already.
UPDATE: the comments asked if I could show schematics, if you will excuse my hand drawn one, for this circuit drawing tool isn't good with ICs.
Dave Tweed had provided the final clue in the comment, so that answers it. But in correct StackExchange-iquette, I put the answer into a separate ... answer ... [drumroll ...]
