I'm trying to get USART working on my atmega8-16PU microcontroller. I've studied the documentation and took the examples of code from there. I've managed to transmit the data from microcontroller to PL-2303HX chip which is connected to my computer via USB enter image description here
The problem is that i receive different data from what i send from mcu. Here is the code:
#define F_CPU 8000000UL // Clock Speed
#define BAUD 9600
#define MYUBRR (((F_CPU / (BAUD * 16UL))) - 1)
void USART_Init( unsigned int ubrr)
    /* Set baud rate */
    UBRRH = (unsigned char)(ubrr>>8);
    UBRRL = (unsigned char)ubrr;
    /* Enable receiver and transmitter */
    UCSRB = (1 << RXEN) | (1 << TXEN);
    /* Set frame format: 8 data bits, 1 stop bit */
    UCSRC = (1 << URSEL) | (1 << USBS) | (1 << UCSZ0);
void USART_Transmit( unsigned char data )
    /* Wait for empty transmit buffer */
    while ( !( UCSRA & (1<<UDRE)) );
    /* Put data into buffer, sends the data */
    UDR = data;
int main()
    USART_Init(MYUBRR);
    while(1)                      /* run continuously */
        USART_Transmit('a');
        _delay_ms(100);
I get 0x80 0x00 at the receiver's side and that is not the 'a' symbol. If it's important a 12 MHz quartz is connected to the PL-2303HX chip. What am I doing wrong?
Most common error: You forgot the (default) Clock Div8 Fuse and your MCU runs on 1 MHz instead of 8 MHz. Try setting your COM Baudrate to 1200 Baud on the PC.
Another nitpick:
#define FOSC 8000000UL // Clock Speed
Notice that you defined FOSC but then used F_CPU in your macro.
  • \$\begingroup\$ Thanks for your reply. As for the define directive it is my fault, I haven't copied the code properly. See the comment above please. I've just tried changing the baud rate of the com port to 1200 without any success. Now i get the 0xE1 from the port code and that is still not the 'a' character \$\endgroup\$
    – roman
    Commented Dec 7, 2012 at 22:53
  • \$\begingroup\$ I've used 2 stop bits with baud rate 1200 and everything seems to work properly! Thanks a lot. But I'm still interested why the data is transmitted incorrectly when using 1 stop bit? \$\endgroup\$
    – roman
    Commented Dec 7, 2012 at 23:10
    \$\begingroup\$ where is DIV8 located? \$\endgroup\$ Commented Jun 15, 2013 at 17:47
You are calculating your baud rate incorrectly. you defined #define FOSC 8000000ULas your clock Clock Speed but your baud rate calculation calls out for for a F_CPU symbol. That symbol is being defined as 1MHz in the #include library. So your calculated baud rate is incorrect as well as the time in your delay. so change that FOSC to F_CPU and define it before the #include of define it as using the -D option for your compiler. Hope this helps
  • \$\begingroup\$ Sorry, i've copied the code incorrectly, FOSC was defined earlier so it didn't get copied. \$\endgroup\$
    – roman
    Commented Dec 7, 2012 at 22:46
