I need to power a 300 W class D amplifier with positive and negative 65 V.
As I'm a do-it-yourself guy, I didn't know about positive and negative voltage and ordered a bunch of these normal step-up converters which were fine for my last projects, where I didn't require + & - voltages:
https://www.ebay.de/i/232461793739
I did some research and found that it is quite easy to get +/- voltage out of two batteries, but I read also that cheap bucket step-ups don't isolate the ground so it can create short-circuits - this was mentioned in posts using ONE battery. As I'm using TWO, is that case not relevant for me?
Here is how I would wire it:
/-------------\ + ---------- + /-----------------------\ + ------ +65V
| 12V Battery | in | 20a Step-Up Converter |out
\-------------/ - ---\ /--- - \-----------------------/ - ------ GND
| ----- | 300W Amplifier
/-------------\ + ---/ \--- - /-----------------------\ - ------ GND
\-------------/ - ---------- + \-----------------------/ + ------ -65V
I'm especially unsure if wiring the lower batteries - to the + of the step-up converter is correct? Also I'm unsure if it will work this way, as I experienced these converters have incorrect polarity protection built-in, to prevent damaging it if you accidentally connect it the wrong way around.
I'm happy if someone can give me a hint how I can get my amplifier to work, without buying other stuff.
