I'm trying to convert +/-12VDC to +/-24VDC to power a DC motor in both directions. I've tried using a step-up converter like this one, but when I feed it -12VDC, it doesn't output anything. Is there an electrical component that will output +24VDC when fed +12VDC and output -24VDC when fed -12VDC? Total noob here just trying to motorize a skylight with a chain actuator, so please excuse my limited understanding.
    \$\begingroup\$ I used to ask this question on job interviews. Google H-bridge. \$\endgroup\$
    – user76844
    Jul 2, 2020 at 3:20
    \$\begingroup\$ Yes, one method is to use a H bridge, such as L298N or L293. "Using L293 H-Bridge to drive DC motor with PWM": electronics.stackexchange.com/questions/114796/…. Cheers. \$\endgroup\$
    – tlfong01
    Jul 2, 2020 at 3:37
I don't think you need a negative supply - just use a double-pole relay to reverse the polarity.
You probably need a center-off switch to allow you to stop the motor wherever you want - or a separate off/on switch.
(You probably killed the DC-DC converter when you connected it with the wrong polarity.)
EDIT due to OP's comment that the controller outputs +12V or -12V...
When the controller outputs +12V, the upper relay will operate. When it outputs -12V, the lower relay will operate.
EDIT 2 Changed the upper relay to DPDT to prevent short circuits should both relays somehow become operated at the same time.
    \$\begingroup\$ @Numbr The suggestion is to use a relay, not a manual switch. \$\endgroup\$ Jul 2, 2020 at 3:27
    \$\begingroup\$ @Numbr: I was thinking switch, but wrote relay when I did the first schematic. The second schematic with two relays should work, if I understand your requirements. \$\endgroup\$ Jul 2, 2020 at 5:17
    \$\begingroup\$ Better hope the timing works out well on the relays so they don't short the 24V supply momentarily. Also I think if the control signal is suddenly removed the coil current may circulate through both relays. \$\endgroup\$ Jul 2, 2020 at 10:50
    \$\begingroup\$ @Mast: I have shown two, double pole relays \$\endgroup\$ Jul 2, 2020 at 15:35
    \$\begingroup\$ @Numbr: You only need a single 24 volt supply. The upper relay connects that supply to the motor with one polarity. The lower relay connects the supply to the motor with the opposite polarity. \$\endgroup\$ Jul 2, 2020 at 15:42
