Is there a way I can check silkscreen clearance with respect to Pads and vias in Eagle 9.5? I don't want to manually check all legends.
Thanks
If you do a manufacturing preview you will see something like this: -
Notice that for the top middle resistor (R2), I deliberately moved the silkscreen component-ident to overlap the left copper pad. I'm talking about R2. Notice how you cannot force the silk screen legend to be printed over copper pads.
In other words you don't need to worry about this if that was the concern you had. But you do need to worry that your silkscreen is legible so use the manufacturing preview to eye over the layout.
  • \$\begingroup\$ Thanks. yes silkscreen is legible. I can see clear texts in manufacturing preview. one problem is, I can not maximize the manufacturing preview window. \$\endgroup\$ Jul 2, 2020 at 14:49
  • \$\begingroup\$ Use the mouse wheel and CTRL button. You can drag the image around also. \$\endgroup\$
    Jul 2, 2020 at 16:05
