I'm planning on powering a 3.3V I2C sensor and its pull up resistors with a linear LDO regulator.
http://www.farnell.com/datasheets/2108564.pdf
The output of the LDO aswell as the sensor's power pins require bypass capacitors. Wouldn't said capactiors together with the pull up resistors act as low pass filters and thus mess up the signals? Calculating the cutoff frequency and lowering the bus frequency accordingly would be one way to solve this I guess. But wouldn't this problem occur with every I2C sensor since every supply voltage trace has buffer or bypass caps on them?
