-1
I have found a 2-channel, USB-powered, ICP® sensor signal conditioner with USB digital output (24-bit A/D). It is supposed to provide me with a digital output that I should be capable to read from my computer. What software could provide me with a row data output file such as .wav?
  • \$\begingroup\$ By "row data output file" do you mean raw? \$\endgroup\$ – Transistor Jul 5 at 12:18
The datasheet says that's a usb audio device, so any audio software can give you a .WAV.
You could buy another usb sound card for a few dollars. Consider carefully if you need to spend $1000 for that device.
Edit: Although it does +/-10V output, so that probably explains the higher cost.
| improve this answer | |
  • \$\begingroup\$ It's slightly unique in the sense that it can provide constant-votlage or constant-current "excitation" to the inputs, whatever that is. \$\endgroup\$ – Dave Tweed Jul 5 at 13:36
  • \$\begingroup\$ it provides the sensor with the current for the internal charge amplifier so it seems to be more expensive. @user1850479 how you figured out the price? I have not seen it... \$\endgroup\$ – Gideon Kogan Jul 5 at 13:54
  • \$\begingroup\$ @GideonKogan: Your own link goes to a page that says "$950.00 USD (Pricing valid in US only)". \$\endgroup\$ – Dave Tweed Jul 7 at 4:16
  • \$\begingroup\$ @DaveTweed, it seems that you see different pages regarding to your location. Maybe I can go around it using VPN... \$\endgroup\$ – Gideon Kogan Jul 7 at 7:55
