I am trying to build a simple project for PIC32MX270F256. The code is just this:
#include <xc.h>
#include "PIC32MX270_STD.h"
#include "Delay.h"
#define LED LATBbits.LATB14
* Function Name: void initMain (void)
* Specification: initializes main
void initMain(void)
    uc_init();              // initialize microcontroller
    TRISBbits.TRISB14 = 0;  // set PINB1 as output
* Function Name: void main (void)
* Specification: main function
void main(void) {
    initMain();         // initializes main function
    while(1)
     LED = !LED;       // toggle LED
     delay_ms(1000);   // delay 1 second
I am using MPLABX v5.30 and XC32 v2.41.
But I am unable to build the project. I get the following errors:
pic32m-gcc.exe: error: build/default/production/PIC32MX270_STD.o: No such file or directory
pic32m-gcc.exe: error: build/default/production/main.o: No such file or directory
pic32m-gcc.exe: error: build/default/production/Delay.o: No such file or directory
make[2]: *** [dist/default/production/01_Blink.X.production.hex] Error 255
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 1s)
Please see the following screenshot for further clarification: enter image description here
Your help is much appreciated.
  • \$\begingroup\$ Seems that the compiler didn't create an output files in a directory where the linker can find them. Either because of compiler errors or because you have some compiler/linker path hiccup, where the compiler places the files in one directory and the linker looks in a different one for them. \$\endgroup\$
    – Lundin
    Jul 6 '20 at 12:55
  • \$\begingroup\$ What happens if you empty MPLABx cache and build ones more? \$\endgroup\$
    – Mike
    Jul 6 '20 at 13:02
    \$\begingroup\$ Check your project settings. Update to v5.40. That's MPLAB X IDE for you, be ready for lots more wierd bugs and errors, where you sometimes have to restart your pc. \$\endgroup\$
    – Swedgin
    Jul 6 '20 at 13:15
  • \$\begingroup\$ Did you copy another project to create this project? \$\endgroup\$
    – HandyHowie
    Jul 6 '20 at 17:34
  • \$\begingroup\$ @Mike Same. The problem doesn't go away. \$\endgroup\$
    – Ahmed
    Jul 7 '20 at 5:35
Problem resolved. Tried @Swedgin's approach: Wiped my PC clean of every software from Microchip, Installed latest versions of only required Softwares and plugins, then built a couple of new projects and all is well so far. Hope it remains like this.
