I'd like to use a TI model for the SN74LVC1G17 in LTSpice.
https://www.ti.com/product/SN74LVC1G17#design-development##design-tools-simulation
I've tried importing the .lib file into lib/sub and using it with a schmitt trigger symbol with the properly named pins (A, Y, GND, VCC) with the same the value field of my symbol given the same name as my .lib file, and I have the .include directive in ltspice.
I've tried several different combinations of the files given at the above link, and I get error messages each time due to pin count and otherwise.
I'm wondering if this part just isn't going to be usable in ltspice or if I'm missing something.
Thanks!
-Andy
Here's more detailed pictures: I'm using SN74LVC1G17.cir from scem635.zip. I saved that as SN74LVC1G17.lib in the LTSPICE lib/sub folder. My symbol is below: enter image description here
With pins VCC, A, Y, and AGND as detailed in the top .subckt statement of sn74lvc1g17.cir. I also did put "sn74lvc1g17" in the value line of the symbol in my schematic.
When I try to run my circuit with a ".include sn74lvc1g17.lib" I get the following: enter image description here
When I try to run it without the .include statement I get this: enter image description here
I have tried many other combinations on files and .include statements but I just don't have the know-how to get the winning answer
sn74lvc1g17.cir (saved as .lib, also tried as .cir in the .include statement):
* SN74LVC1G17.cir
* 2.0
* 2019-11-14 00:00:00
* Texas Instruments Incorporated.
* Standard Logic, SLHR
* 12500 TI Blvd
* Dallas, TX -75243
* Revision History:
* Rev 2.0: 01/01/2019
* - Model generated from datasheet values
* - Built using generic logic gate behavioral pspice model V2
* - Built using an automated model which generalizes parts under same family
* - Performance is expected typical behavior at 25C
* - Written for and tested with Tina-TI Version 9.3.100.244 SF-TI
* - Accurate power consumption with dyanmic as well as static Icc
*[Disclaimer]
* This model is designed as an aid for customers of Texas Instruments.
* TI and its licensors and suppliers make no warranties, either expressed
* or implied, with respect to this  model, including the warranties of
* merchantability or fitness for a particular purpose. The model is
* provided solely on an "as is" basis. The entire risk as to its quality
* and performance is with the customer.
*[Copyright]
*(C) Copyright 2019 Texas Instruments Incorporated.All rights reserved.
*                                 SN74LVC1G17
.SUBCKT SN74LVC1G17 Y A VCC AGND
XU1 Y A VCC VCC AGND LOGIC_GATE_2PIN_OD_LVC_1i_AND_PP_ST_SN74LVC1G17
.ENDS
.SUBCKT LOGIC_GATE_2PIN_OD_LVC_1i_AND_PP_ST_SN74LVC1G17 OUT A B VCC GND
.PARAM VCC_ABS_MAX = 6.5
.PARAM VCC_MAX = 5.5
.PARAM RA = 220000000
.PARAM RB = 220000000
.PARAM CA = 4.5e-12
.PARAM CB = 4.5e-12
.PARAM ROEZ = 5500000
.PARAM COEZ = 6e-12
RA  A  GND {RA}
RB  B  GND {RB}
CA  A  GND {CA}
CB  B  GND {CB}
XUA NA A VCC GND LOGIC_INPUT_LVC_1i_AND_PP_ST_SN74LVC1G17
XUB NB B VCC GND LOGIC_INPUT_LVC_1i_AND_PP_ST_SN74LVC1G17
XUG NA NB NOUTG VCC GND LOGIC_FUNCTION_2_LVC_1i_AND_PP_ST_SN74LVC1G17
XOUTPD NOUTG NOUTTPD VCC GND TPD_LVC_1i_AND_PP_ST_SN74LVC1G17
XUOUT NOUTTPD NOUT_INT VCC GND LOGIC_PP_OUTPUT_LVC_1i_AND_PP_ST_SN74LVC1G17
XICC VCC GND NVIOUT LOGIC_ICC_LVC_1i_AND_PP_ST_SN74LVC1G17
SICC VCC GND VCC GND SW1
H1 NVIOUT GND VIOUT 1
VIOUT NOUT_INT OUTsw 0
SIOFF OUTsw OUT VCC GND SW2
DA2 GND A D1
DB2 GND B D1
DO2 GND OUT D1
RDA1 NA1 GND 1e6
SDA1 NA1 A VCC GND SW2
RDB1 NB1 GND 1e6
SDB1 NB1 B VCC GND SW2
RDO1 NO1 GND 1e6
SDO1 NO1 OUT VCC GND SW2
.MODEL SW1 VSWITCH VON = {VCC_ABS_MAX} VOFF = {VCC_MAX} RON = 10 ROFF = 60e6
.MODEL SW2 VSWITCH VON = {0.55} VOFF = {0.45} RON = 10m ROFF = 100e6
.MODEL D1 D
.ENDS
.SUBCKT LOGIC_INPUT_LVC_1i_AND_PP_ST_SN74LVC1G17 OUT IN VCC VEE
.PARAM STANDARD_INPUT_SELECT = 0
.PARAM SCHMITT_TRIGGER_INPUT_SELECT = 1
ESTD_THR VSTD_THR VEE TABLE {V(VCC,VEE)} =
+(1,0.5)
+(1.8,0.9)
+(2.5,1.25)
+(3.3,1.65)
+(5,2.5)
+(6,3)
ETRP_P VTRP_P VEE TABLE {V(VCC,VEE)} =
+(1.65,0.9)
+(2.3,1.25)
+(3,1.7)
+(4.5,2.45)
+(5.5,3)
ETRP_N VTRP_N VEE TABLE {V(VCC,VEE)} =
+(1.65,0.45)
+(2.3,0.7)
+(3,1.05)
+(4.5,1.72)
+(5.5,2.1)
EHYST VHYST VEE TABLE {V(VCC,VEE)} =
+(1.65,0.45)
+(2.3,0.55)
+(3,0.65)
+(4.5,0.73)
+(5.5,0.9)
ETRUE NTRUE VEE VALUE = {V(VCC,VEE)}
EFALSE NFALSE VEE VALUE = {0}
EBETA BETA VEE VALUE = {V(VHYST,VEE)/(V(NTRUE,VEE) - V(NFALSE,VEE) + V(VHYST,VEE))}
EFB NFB VEE VALUE = {(1 - V(BETA,VEE))*V(IN,VEE) + V(BETA,VEE)*V(CURR_OUT,VEE)}
EREF NREF VEE VALUE = {0.5*(1 - V(BETA,VEE))*(V(VTRP_P,VEE) + V(VTRP_N,VEE))
+ + 0.5*V(BETA,VEE)*(V(NTRUE,VEE) + V(NFALSE,VEE))}
EDIFF NDIFF VEE VALUE = {V(NFB,NREF)}
ESWITCH VSWITCH VEE VALUE = {0.5*(-SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
ESWITCH1 VSWITCH1 VEE VALUE = {0.5*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
GCOMP VEE CURR_OUT VALUE = {SCHMITT_TRIGGER_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
GSTD VEE CURR_OUT VALUE = {STANDARD_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(IN,VSTD_THR)) + ABS(SGN(V(IN,VSTD_THR))))}
ROUT CURR_OUT VEE 1
EMID MID VEE VALUE = {0.5*(V(VCC,VEE) + V(VEE))}
EARG NARG VEE VALUE = {V(CURR_OUT,VEE) - V(MID,VEE)}
EOUT OUT VEE VALUE = {0.5*(SGN(V(NARG,VEE)) + ABS(SGN(V(NARG,VEE) ) ) )}
.PARAM MAXICC = 0.032
.PARAM VT = .7
.PARAM VCC_MIN = 1.65
EV_VT1 VTN VEE VALUE = { VT }
EV_VT2 VTP VEE VALUE = { V(VCC,VEE) - VT }
ETEST TEST VEE VALUE = {.9*V(VCC,VEE)}
EVTHDIFF VTH_DIFF VEE VALUE = {V(IN,VSTD_THR)}
EVTHPDIFF VTHP_DIFF VEE VALUE = {V(IN,VTRP_P)}
EVTHNDIFF VTHN_DIFF VEE VALUE = {V(IN,VTRP_N)}
EVTNDIFF VTN_DIFF VEE VALUE = { V(IN,VTN) }
EVTPDIFF VTP_DIFF VEE VALUE = { V(IN,VTP) }
GICCVA VCC VEE VALUE = { (-ABS(( (1+SGN(V(VTN_DIFF,VEE)) ) )/2 -1) *
+ 2*MAXICC*((V(IN,VEE)-VT)/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH,VEE)}
GICCVB VCC VEE VALUE = { (ABS(( (1+SGN(V(VTHP_DIFF,VEE)) ) )/2 -1) *
GICCVC VCC VEE VALUE = { ( ABS(  (1+SGN(V(VTHN_DIFF,VEE)) ) )/2  *
+ 2*MAXICC*((V(IN,VEE)-(V(VCC,VEE)-VT))/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH1,VEE)}
GICCVD VCC VEE VALUE = { (-ABS(  (1+SGN(V(VTP_DIFF,VEE)) ) )/2  *
.ENDS
.SUBCKT LOGIC_FUNCTION_2_LVC_1i_AND_PP_ST_SN74LVC1G17 A B OUT VCC VEE
.PARAM AND  = 1
.PARAM NAND = 0
.PARAM OR   = 0
.PARAM NOR  = 0
.PARAM XOR  = 0
.PARAM XNOR = 0
GAND  VEE N1 VALUE = {AND*V(A,VEE)*V(B,VEE)}
GNAND VEE N1 VALUE = {NAND*(1 - V(A,VEE)*V(B,VEE))}
GOR   VEE N1 VALUE = {OR*(MIN(V(A,VEE) + V(B,VEE),1))}
GNOR  VEE N1 VALUE = {NOR*(1 - MIN(V(A,VEE) + V(B,VEE),1))}
GXOR  VEE N1 VALUE = {XOR*((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE)))}
GXNOR VEE N1 VALUE = {XNOR*(1 - ((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE))))}
RN1 N1 VEE 1
EOUT OUT VEE N1 VEE 1
.ENDS
.SUBCKT TPD_LVC_1i_AND_PP_ST_SN74LVC1G17 IN OUT VCC VEE
.PARAM TPDELAY1 = 1N
.PARAM RS = 10K
.PARAM CS = {-TPDELAY1/(RS*LOG(0.5))}
ETPDNORM NTPDNORM VEE TABLE {V(VCC,VEE)} =
+(1.8,4.3)
+(2.5,2.6)
+(3.3,2.15)
+(5,1.95)
G1 IN N1 VALUE = {V(IN,N1)/(V(NTPDNORM,VEE)*RS)}
RZ IN N1 10G
C1 N1 VEE {CS}
E1 N2 VEE VALUE = {0.5*(1 + SGN(V(N1,VEE) - 0.5))}
EOUT OUT VEE N2 VEE 1
.ENDS
.SUBCKT LOGIC_PP_OUTPUT_LVC_1i_AND_PP_ST_SN74LVC1G17 IN OUT VCC VEE
EROH NROH VEE TABLE {V(VCC,VEE)} =
+(1.65,112.5)
+(2.3,50)
+(3,37.5)
+(4.5,21.875)
EROL NROL VEE TABLE {V(VCC,VEE)} =
+(1.65,112.5)
+(2.3,37.5)
+(3,25)
+(4.5,17.1875)
E1 N1 VEE VALUE = {V(VCC,VEE)*V(IN,VEE)}
GOUT N1 OUT VALUE = {V(N1,OUT)*(V(IN,VEE)/V(NROH,VEE) + (1 - V(IN,VEE))/V(NROL,VEE))}
.ENDS
.SUBCKT LOGIC_ICC_LVC_1i_AND_PP_ST_SN74LVC1G17 VCC VEE VIOUT
.PARAM ICC = 2.5e-07
GICC VCC VEE VALUE = {ICC*0.5*(1 + SGN(V(VCC,VEE) - VCC_MIN))}
EGNDF GNDF 0 VALUE = {0.5*(V(VCC) + V(VEE))}
GOUTP VCC GNDF VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
GOUTN GNDF VEE VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
.ENDS
Here's my .asy file:
Version 4
SymbolType CELL
LINE Normal 8 72 16 72
LINE Normal 12 56 20 56
LINE Normal 12 72 12 56
LINE Normal 16 72 16 56
LINE Normal 0 32 64 64
LINE Normal 0 96 64 64
LINE Normal 0 96 0 32
WINDOW 0 8 16 Left 2
WINDOW 3 8 120 Left 2
SYMATTR Prefix A
SYMATTR SpiceModel SCHMITT
SYMATTR Description Behavioral Schmitt-Triggered buffer with complementary outs
PIN 0 64 NONE 0
PINATTR PinName A
PINATTR SpiceOrder 1
PIN 0 32 NONE 8
PINATTR PinName VCC
PINATTR SpiceOrder 2
PIN 64 64 NONE 8
PINATTR PinName Y
PINATTR SpiceOrder 3
PIN 0 96 NONE 0
PINATTR PinName AGND
PINATTR SpiceOrder 4
    \$\begingroup\$ "using it with a schmitt trigger symbol with the properly named pins" -- can you show the symbol? "I get error messages" -- what messages? I just tried it with the symbol for [Misc]/tetrode, at a whim, and it works. Most probably you're using it with the [Digital]/inv symbol, improperly, and you haven't handled the custom library correctly. I find it surprising that, when you wrote your question, there were no suggested answers, there are quite a few good ones to choose from, such as this one. \$\endgroup\$ – a concerned citizen Jul 7 at 16:05
  • \$\begingroup\$ I used it with the schmitt signal, but modified so it has an input (A), output (Y), VCC and GND. I'll take a look at that other answer, thanks \$\endgroup\$ – Andy M Jul 7 at 16:09
  • \$\begingroup\$ @aconcernedcitizen I edited my post with pictures and more detailed explanation of my problems. FWIW I also tried with the hspice .lib file and got even more problems, as when I open that in a text editor there is no .subckt statement. I also took a look at the post you linked and wasn't able to glean any solution from that unfortunately. I'd love to know how you got this working. \$\endgroup\$ – Andy M Jul 7 at 16:32
  • \$\begingroup\$ @AndyM I've not taken any time. Just looked at your error messages. Both are fairly well-stated and understandable. Let's start with the 2nd one. This one exposes the .SUBCKT call, which appears to use eight nodes! Feel free to count for yourself. The 1st error message, once you include the .SUBCKT by including a file I haven't bothered reading, tells you that the eight nodes passed doesn't match up right. So all you have to do is go look and work out why the call or SUBCKT subroutine or symbol don't match in their parameter counts. \$\endgroup\$ – jonk Jul 7 at 16:42
    \$\begingroup\$ @AndyM if you think the question is useful for other people, then please post your own answer. If it's not, then delete the question. Thanks \$\endgroup\$ – Voltage Spike Jul 7 at 18:04
