When wiring solar cells in parallel, the current is additive but the voltage remains the same. On the other hand, when wiring solar cells in series the voltage is additive, but the current remains the same.
My question is, what would happen if you had one large solar cell that occupied the space of the entire panel (roughly the size of 36 individual solar cells, or slightly larger if you take into account the extra space that you get from not having individual cells spaced out). Would the voltage and current be roughly that of 36 cells in parallel, in series, or some different number?
