The OpAmp configuration below has two switch:
The close-loop gain and bandwidth on switch 1 is:
: A_v(CL) =1 and bandwidth of 1MHz
I don't understand why at switch1 the gain is 1, I thought it will be zero since its common-mode signal.
And if ever the gain is really 1,why would the upper bandwidth be 1MHz? I learned before that: $$f_{2(CL)}=\frac{f_{unity}}{A_v(CL)+1} $$ So the bandwidth must be:
$$f_{2(CL)}=\frac{1MHz}{1+1}=500KHz$$
Why at switch 1 the closed-loop gain is 1 and not 0 and why the bandwidth is 1MHz and not 500KHz(if ever the gain is really 1)?
