I have just bought the following 5-pin switches of eBay: here 5-pin switch
Problem is that no spec came with it and I am now wondered if I can directly wire the LED pins to the main or if I need to add extra electronics.
  • \$\begingroup\$ Why don't you ask the seller? If there is no info how to use it, why did you buy it? \$\endgroup\$ – Justme Jul 9 '20 at 15:07
  • \$\begingroup\$ Does this answer your question? Wiring a 5 Pin LED Switch \$\endgroup\$ – Michel Keijzers Jul 9 '20 at 15:11
  • \$\begingroup\$ @MichelKeijzers, not really, I did read this thread before posting my thread, thanks :-) \$\endgroup\$ – toughQuestions Jul 9 '20 at 15:15
    \$\begingroup\$ Ok, I retracted my closing/duplicate vote. Better ask the seller as said above. \$\endgroup\$ – Michel Keijzers Jul 9 '20 at 15:21
    \$\begingroup\$ @MichelKeijzers, yes that is the first thing I did, but I have not received any answer yet :-) \$\endgroup\$ – toughQuestions Jul 9 '20 at 15:24
The LED voltage is part of the ordering options, so if you selected 220VAC, and they got the order right, that should be the correct voltage.
  • \$\begingroup\$ Ok, great, so I should be fine then. It would be a shame to blow it up :-) \$\endgroup\$ – toughQuestions Jul 9 '20 at 15:14
    \$\begingroup\$ Chances are still non-zero. \$\endgroup\$ – Spehro Pefhany Jul 9 '20 at 15:15
    \$\begingroup\$ Ok, I wired the 2 LED pins directly to the main and it did not blow up, yeah! :-) \$\endgroup\$ – toughQuestions Jul 9 '20 at 16:43
The seller provided the wiring diagram. I am adding it as an answer as I believe it may help other people to understand how these swtches work. enter image description here enter image description here
