Question is weird but it's about something that I really want to try.
AC power here in India has 50Hz frequency. What I really want to try is to make a series path with two continuous conversions. In start, I want to convert 50Hz AC 230V signal to 100Hz 230V AC signal and at the end of this path I want it to became the same signal of 50Hz AC 230V. That is, I want to convert the frequency of the signal at both ends. At one end multiply it by double and at the other end devide by half. How can I do this?
I tried the cyclo converter circuit but couldn't find the proper result. Is there any modification required in the cyclo converter or any other method available?
  • \$\begingroup\$ If you are looking at a cycloconverter, then you probably aren't looking at "signals." That kind of thing is generally applied to power lines. \$\endgroup\$ – JRE Jul 10 '20 at 13:04
  • \$\begingroup\$ Normally a frequency doubler would work, but they are not meant for raw power, only signals. The parts would be bulky and expensive and waste power. \$\endgroup\$ – user105652 Jul 11 '20 at 4:21
I can give a suggestion. May not work out. It goes something like this, if you don't want to get into complicated complex solution such as AC(50)-DC-AC(100)-DC-AC(150). Please comment if solution seems to be in lines of what you have been implementing.
  • A: 50 Hz signal
  • After passing A signal through a switched converter working to produce something like in Fig. B(Switching at 90 degree to alternate the waveform), you get a 100Hz signal. Now this signal contains many harmonics as n*100Hz.
  • To get the required 100Hz signal, you can pass it through the LPF Filter with cut-off frequency of 100Hz. Getting required 100 Hz signal.
Note: There are many things that needs to be pointed out in this simple looking solution such as:
  • Desired Output 230V may not be the output as there would be attenuation in the circuit
  • Proper 100Hz sine wave may not be there. Since LPF filter are not exactly cut-off at frequency. They have some roll-off rate.
  • Converter might be required to go from A->B. Might complicate the solution
  • Solution seems to be similar to cyclo-converter
  • Filter used may be bulky if used for high-power.
  • \$\begingroup\$ Yes its exectly i want but with the usage of these switched converters as you said harmonics, it will be the problems. suggest if you have more ideas in this or any other. cause i want atleast 90% same output as input (50hz AC) \$\endgroup\$ – Jasmin Temp Jul 10 '20 at 17:26
