If you have long PCB traces and want to minimize the resistance, is it feasible/viable to use through hole vias to be able to utilize copper on both sides of the board? If width of the trace is limited, what might other strategies be? Thicker copper? Looking for solutions that are most economic in scaled production.
    \$\begingroup\$ Not denser, but thicker. Up to 3 oz. (105 um) is readily available from most vendors. \$\endgroup\$
    – Dave Tweed
    Jul 11, 2020 at 16:59
  • \$\begingroup\$ If only a few traces need to carry high current, can you be more specific on current and max voltage drop or resistance and path length and cost? Busbars are economical solutions. Vague questions are unanswerable. \$\endgroup\$ Jul 11, 2020 at 19:26
  • \$\begingroup\$ Dave Jones discusses this topic briefly here while showing an interesting approach that one manufacturer has used - leaving the trace exposed and tinning it during wave soldering: youtu.be/g94mpom2Ahs?t=17m22s \$\endgroup\$ Jul 11, 2020 at 21:21
You could use traces on both sides, or internal traces, in parallel. You could use thicker copper (for example, pcbway has up to 13oz copper available on outside layers and even thicker copper is available from some suppliers). The cost of ultra-thick copper can be quite high, but the process is suitable for volume production. Here's a 20oz board, photo from here:
IPC2152 now contains information on thicknesses up to 30oz copper, as in this board (photo from here):
As well as the cost (setup and unit cost), and limited suppliers with the capability, ultra-thick copper tends to greatly limit the density of connections (minimum trace width and minimum space) even with the anisotropic plating/etching techniques that they use (in an attempt to get vertical walls on the traces).
You can also solder jumper wires onto the traces (or replace the traces with jumper wires) or use bus bars on the PCB. Pulling back the solder mask to allow solder over the traces can reduce the resistance, you'll sometimes see that in high volume power supplies. I don't think the increase in conductivity is enormous (WAG maybe 30% less resistance), but it's almost free.
  • \$\begingroup\$ Yeah, the resistivity of solder is approximately 10x that of copper, so just to halve the resistance, you'd need to build up 350 um of solder over a 35 um copper trace, over its full width. \$\endgroup\$
    – Dave Tweed
    Jul 11, 2020 at 17:13
  • \$\begingroup\$ @DaveTweed Making a rough measurement on an old Aztec power supply board using a micrometer, I get solder thickness of ~0.3mm average, so maybe a 30% reduction on 2 oz (70um) copper. \$\endgroup\$ Jul 11, 2020 at 17:29
  • \$\begingroup\$ @SpehroPefhany np, it's an awesome-looking board! More pictures, including soldering and assembly in this gallery. \$\endgroup\$
    – marcelm
    Jul 11, 2020 at 18:57
  • \$\begingroup\$ That board is hilarious. Copper that thick just looks bizarre. \$\endgroup\$ Jul 11, 2020 at 19:14
