I'd like to identify or find a replacement for a LDO component in the board above:
LDO in question with a ruler next to it
  • It's a 3.3V LDO.
  • It reads "AMS1117 3.3 DN18".
  • The body is around 4mm width.
  • Similar to SOT-223 package, but it's smaller.
I was looking for AMS1117 but according to datasheet it is available only in SOT-223, TO-252 and SO-8 factors.
He're another photo, with a SOT-223 AMS1117 that I had at hand. I was considering bending LDO but then I saw that top "tab" pin won't fit, so it doesn't look like a viable option.
Top view
It could be a SOT-89 package like this version of the AMS1117: -
A SOT89-3 package looks like a smaller version of a SOT-223.
The body will be around 4.5 mm in width, and the lead spacing is 1.5 mm or 3 mm between the centerlines of the outer leads.
Armed with an idea of the package, go to your favorite supplier and put that and your other needs into their selector.
Some second-source vendors make the AMS1117 in other packages, such as the 4.5mm SOT-89.
