So I am trying to create a delay using a timer but doesn't seem like it's working as expected.
With a clock of 16MHz and a prescaler of 1, it should take 10us to reach a count of 160 (unless I did something wrong).
static void MX_TIM2_Init(void)
    __HAL_RCC_TIM2_CLK_ENABLE();
  TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  /* USER CODE END TIM2_Init 1 */
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 1;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period =  160;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
    Error_Handler();
void Delay() {
    while (1) {
        if(__HAL_TIM_GET_FLAG(&htim2, TIM_FLAG_UPDATE))
            GPIOC->ODR ^= GPIO_PIN_10;
Capture:
  • \$\begingroup\$ Do you ever clear the flag after it gets set? If not then you're just timing how long your while loop takes to execute. \$\endgroup\$
    – brhans
    Jul 13, 2020 at 17:21
  • \$\begingroup\$ are you referring to auto reload register's value being set? doesn't the value reset to 0 after reaching the max count? \$\endgroup\$
    – MKD
    Jul 13, 2020 at 18:15
  • \$\begingroup\$ No, I'm referring to the TIM_FLAG_UPDATE you're reading with __HAL_TIM_GET_FLAG. Surely you need to clear that in your code after you see it get set by the timer hardware ... ? \$\endgroup\$
    – brhans
    Jul 13, 2020 at 18:50
  • \$\begingroup\$ I see a pulse width of 20us instead of 10us \$\endgroup\$
    – MKD
    Jul 13, 2020 at 18:58
    \$\begingroup\$ You're setting htim2.Init.Prescaler = 1;, but the actual prescaler used by the timer is "PSC + 1" (datasheet page 368, section 3.4.11). \$\endgroup\$
    – brhans
    Jul 14, 2020 at 20:48
