Main signals comes under the source-synchronous group are data, ECC and strobe lines. My understanding about source-synchronous signal is that all of these signals would be latched on both edges of the clock signals and the direction of clock and source-synchronous signals are be same. What is source clocked signals? How is it different from source-synchronous signals? ( Source clocked signals - Address, Bank address, bank group, clock enable etc)
1 Answer
Nothing. They're the same thing if you're talking about DDR3 or DDR4.
You're probably thinking that there's something to this based on Intel's use of the term, for example in this doc: https://www.intel.com/content/dam/www/public/us/en/documents/white-papers/ia-ddr2-ecc-so-dimm-paper.pdf
Don't be misled. In reality all the signals in DDR4 are source-synchronous. The ADDR/CMD group references CLK, and all are launched from the host together; while DQ references DQS which is launched from the host on writes and from the DRAM on reads.
In fact, multi-chip DDR3 and DDR4 explicitly rely on source-sync clocking to support daisy-chain (fly-by) routing. They have the added ability to level the ADDR/CMD/CLK to DQ delay which allows the DQ/DQS signals on a multi-chip rank to have less skew (that is, similar CMD to DQ latency.)
