I have a question on the mosfet construction. Considering a n-channel enhancement type mosfet, it has two n-type regions connected to source and drain terminals. Also there is a p-type substrate. If source is connected -ve and drain is connected +ve voltage, there is no current flow unless there is a positive voltage in the gate which attracts some electrons to form the n-channel and hence conduction occurs.
It seems the same effect could be achieved using only one n type region connected to drain and no n-type region connected to source in the mosfet. alternate mosfet implementation
There would be an depletion region with p-n reverse biased (drain +ve and source -ve). Gate being in a positive voltage can create a n-channel and let current flow. The device could operate in pinch-off or linear or saturation region.
I was getting the feeling the source side n-region is redundant. Would like to know if it serves a purpose?
  • \$\begingroup\$ I'm not a device manufacturing expert, but I'd guess that drilling a hole in the surface of a wafer and plating a metal electrode into it would involve adding new process steps. \$\endgroup\$
    – The Photon
    Jul 14, 2020 at 16:42
  • \$\begingroup\$ Yes, as @ThePhoton writes, the metal layer is deposited after n and p wells and the insulating oxide layer, and cannot be trenched that deeply into the substrate. It has to do with process steps, temperatures...etc. \$\endgroup\$
    – P2000
    Jul 14, 2020 at 17:01
What you are proposing is called a Schottky-Barrier Source and Drain MOSFET:
Compare this n/p well MOSFET
with this metal source/drain MOSFET
Images from https://www.semanticscholar.org/paper/Electrical-Characterisation-and-Modelling-of-metal-Pearman/f3d7a94a98b10c7c36e527c697eb3d158d69d4c0
See also https://people.eecs.berkeley.edu/~tking/theses/rvega.pdf
The metal S/D lowers the Rds and improves the ft, but the Schottky barrier doubles the threshold voltage.
